Results 1 to 7 of 7
    My friend has esi matic
    Recently, nagkakaproblema ciya
    Battery seems to be good, kapag nakaignite, ok power window, lock, lights busina so mukhang di ciya battery
    MEron din ciya redondo, pero ayaw tumuloy, so think di ciya mukhang starter,,
    what could be the problem kaya peeps? Help us..thanks
    Quote Originally Posted by matrixx View Post
    Ano ba tunog ng makina during start-up? Malakas ba ang starter? Kapag nag start ka at tuloy tuloy ang starter na parang walang load?, pabuksan mo distributor cap. Start the engine and let someone observe in the distributor cap kung umiikot during starting. Kapag hindi, tyak naputolan ka ng timing belt kaya ayaw mag start makina.
    nakopo wag naman sana...
    pero parang ganon, malakas ang redondo pero ayaw tumuloy...
    Will tell my friend....i hope di putol tim,ing belt
    thanks
    servo daw problema..
    magkano kaya yun?
    Sep 2005
    sir gnyan din po ESi ko dati, ayaw magtuloy till maubos ung battery. nilagyan ng relay ung starter ko ok naman until now hindi na nagloloko.
    Jul 2003
    before you panic about the timing belt, check first if the car has fuel. if it has, check if the fuel pump works.
Honda esi matic ,,not starting
