Hi,
Ask ko lang I noticed my car latey na when it's running in 2nd or lower gear parang kumakadyot or parang may pumipigil then bibitawan. Anyone has any ideas on this? Medyo nakakabother na rin kasi. TIA.![]()
Hi,
Ask ko lang po kung saan kaya nanggagaling yung langis. Tumutulo kasi sa may transmission area.
Salamat!
Newbie here, patulong po ako to identify itong naka bypass na ito. kabibili ko lang nito Honda city 2004, ok naman sya tumakbo at maayos pa ang kaha. napansin ko lang after kong mag palit ng mga radiator hose clamp belt, nasa ilalim kasi ng engine air filter kaya hindi naming napansin. saan po kaya ito nakakabit anu kaya na bypass dito, worry kasi ako kasi family ko ang nasakay. ayaw ding sumagot ng seller pag t-text ko. salamat po.
[IMG]P70716-094223[1][/IMG]
Sir the other image is broken. Can you send again?
Sent from my SM-G930F using Tsikot Forums mobile app
Hindi po kaya mod? Just basing on one pic, I cant find any other wire on that area.
nakita ko na kung saan sya naka lagay sa fan switch sensor (correct me if I'm wrong) the previous owner bypass the fan switch (let the fan always on). siguro nag malfunction yung fan switch sensor kaya na bypass..hoping na yun lang talaga problema kaya lang bago mo malalaman yung fan ang problema mag overheat muna..
BTW any dis advantages with fan always on?
salamat po sa inyo..
[IMG][/IMG]
It could be coming from that hose based on the 3rd picture. It doesnt look like a transmission cooling hose though.
More pictures perhaps. You can also touch the underside of the hose once your engine bay is cold.
I am hearing unusual sound/noise in the engine bay, specifically around where the belt is. Ignore the clicking sounds coming from the engine block itself. Here's the video: Honda City Weird Engne Noise - YouTube
May nabibili bang weather stripping for this City generation?
