Results 1 to 8 of 8
    Feb 2009
    mga kuya help nmn po ulit.
    this past week tuwing am. na pansin pag mag start ako ng car honda esi95. lumalabas yung chek engine, tapos d n nawawala so medyo kinakabahan ako after tumakbo ng 2 mins off ko ulit car, start ulit ayun pag start ko ilaw sya then 2 to 3 seconds mawawala n yung chek engine.
    s tuwing mag start ako ng car this week pag d nmmtay yung chek engine n ilaw, nag restart ulit ako. s second restart ko ok nmn sya nwawala yung chek engine after 2 to3 seconds.
    may bayad b kung sakali n pa diagnose k s casa yung kotse?
    anung il po b maganda gamitin ko? mag pa change oil ako this month?
    my idea po b ag kano mag pa camber?
    Sep 2006
    try mo padiagnose sa kasa may print out silang ibibigay sayo kung ano ung problem.then pagawa mo sa labas. also try resetting the ECU or you can diagnose the car by shorting a blue connector under your glove compartment then from the flashes you read the cods but you'll be needing a manual.
    Feb 2009
    salamat po, this week dalahin s casa, yung manual n png read ng code s chek engine nkakapag download po ba ng manual s internet?
    salamat po.
    kahit nalaman na yung codes ,kailangan pa rin further diagnostics para sigurado , bago bumili ng parts na involved
    May 2007
    Tama sila. And repair now, is going to be a lot cheaper, than running it until it dies. So, while money is tight now, just consider that. If you ignore it, whatever is going wrong, will continue, until it damages other things. Then you'll have twice, or three times as many things to fix.
    Quote Originally Posted by v6dreamer View Post
    +1 ditto. meron naman kahit hindi casa na pangdiagnose ng engine check light. try speedyfix sa may shaw. meron sila dun AFAIK.
    Jan 2008
    Sir san po ung speedyfix (exact location po).
    Apr 2004
    Quote Originally Posted by onkyo View Post
    umiilaw yan sometimes due to:
    loose/wet sensor
    broken mass air flow sensor
    i've heard na umiilaw din ito pag pasira na timing belt mo. include this when you have it checked.
honda95 esi check engine sign
