Results 1 to 6 of 6
    Guys! Need your inputs on the above subject - Please.....tried turning off the a/c, while the car is running suddenly felt sudden surge of power to the engine..(feel mo kse after that humatak na ulit)..thank you!!
    Quote Originally Posted by Tsunayoshi View Post
    sir ganon po talaga, mas malakas humatak ang sasakyan pag di po naka aircon.
    Quote Originally Posted by switch3000 View Post
    Ty bro..i know..kaya lang this is different (as in hirap talaga..parang ayaw na umandar)..
    ganyan din sa kin dati pare, pina tune up ko, sabi nung mekaniko kulang daw ng apat na ngipin yung timing nung nagpapalit kasi ako ng cylinder head gasket baka daw hindi naibalik sa factory settings yung timing belt kaya ayun..
    try mo muna pa tune up pare, don sa mekaniko na marunong sa honda, basta sabi nung mekaniko may palatandaan daw kasi sya sa timing non e.. baka yun lang problema
    Thank you bro!
    You may also want to have your aircon system checked for low freon level or any anomaly that involves the compressor. It may be giving the engine more load than it should, resulting in poor fuel economy and poor acceleration when engaged.
Hirap Humatak if a/c is on '93 Esi
