Results 1 to 5 of 5
    I'm just a newbee...
    Need help on power problem.
    Intermittent sya... wlang power yung aircon kapag ni-i-start. Kailangan ko pang katukin yung ilalalim ng fuse box para magka-power.
    Also, where can I find a good latero service. My area is in San Pedro, Laguna.
    Sombody told me that ang ginagamit na sa latero ngayon ay fiber glass na at hindi na yero... is this true?
    Quote Originally Posted by nyokee View Post
    Kinda obvious that you have loose electrical connections at your fuse box. You'll just need to visit a car electrician or similar to have it sorted out and fixed in a more permanent matter.
    Thanks ghosthunter...
    will do that..
    Also, is it normal na humihina yung ilaw nung aircon panel once the headlight is on? i've already changed the alternator... and the battery is new....
    You have any idea on latero service? how much it will cost? kalawang na kasi yung sa likod... yung malapit na sa gulong... nagtanong na ko dito malapit sa amin... it will cost 4K on each panel... so 8K for 2 panels...
    Thanks
    Well, normal for older cars because the grounding terminal (of the battery) might need to be "re-grounded" or additional electrical grounding added to the body.
    No idea on the latero costing.
    Thanks ghost hunter...
Need Help/Advise: Namamatay yung power ng aircon on Honda ESI '94
