Results 1 to 16 of 16
    Apr 2006
    We just bought a Honda City 2008 A/T model. There's just one problem (we have been informed by the former owner). Sometimes when in Park mode, it would not start. But when you put it in Neutral or wiggle the lever a bit, it would start.
    Has anybody experienced this on their Honda City models. Or is this related to the dreaded CVT problem. I was hoping it's just a sensor problem. Please advise. Thanks in advance.
    Mar 2012
    same problem with me... siguro loose connection lang or something... i get by with it... might have to have it checked though...
    since your city is the last mmc city, it would be possible that it wouldn't be affected by the cvt problem... earlier models were probably damaged because hcpi placed atf in the tranny instead of cvtf.
    i own a 2006 city cvt and thankfully i haven't experienced any tranny problems. its already running at 140k kms. just have to religiously change cvtf every year or every 20k km.
    Dec 2012
    Suggest you check when was the last time the cvt oil was changed. Should be every 2 years at least. Pacheck agad mas mahal pag lumaki ang sira.
    Aug 2009
    is it every 2 years or every 40K? or kung ano mauna?
    Dec 2012
    Quote Originally Posted by chrismarte View Post
    can't recall every ilang km pero sure ako sa 2 years
    Apr 2013
    Ser landlord, if ever na kailangn nyo ng brake pads and disk rotor for your honda city 2008, pm mo lang ako baka sayo ko mabenta ang mga ito. Original lahat to from casa at hindi pa nagamit. Naitrade-in ko kasi yong kotse ko for SUV at saka huli na ng dumating kaya hindi ko na napa-install yong parts.
    Dec 2013
    Quote Originally Posted by Leke View Post
    Boss ano cp number mo
    Experienced the same problem before with my old Expedition in Illinois. There was something wrong with the starter sensor. The problem was a bit erratic as it happens once in a while but not all the time. It started when my starter motor started having some problems.
    Aug 2012
    Quote Originally Posted by landlord View Post
    Hello Sir ask ko lang kung ok na yung car mo regarding starting issue parehas ksi tayo ng symptoms kya gusto ko sana malaman kung anong inayos sa car mo ,ty sir
    Apr 2014
    How much ba sa casa mag palit ng cvtf?
    Jul 2012
    ngyayari sakin yan dati. while in "P" ayaw mag start. ginagawa ko apak break, shift sa R-N-D-S-L then pabalik sa P, tapos yun mag start na. not sure pero hindi ata pumapasok ng maigi yung P kaya ayaw mg start kaya need pa ulitin. pero when i replaced my tranny never na ulit ngyari.
    It is the neutral safety switch (NSS) or its equivalent in Honda...
    Purpose of which is to prevent the engine from being started unless you're in 'P' or 'N'
    Obviously, the car does not recognize that you're in 'P' or 'N' and that is why it does not start,- and the necessity to wiggle or to play around with the AT lever.....
    25.8K:shazam:
    worn a/t switch Lang or loose cable connecting the lever to the switch. Jack up the car and check. use Jack stands...
    Aug 2012
    25.8K:shazam:
    same symptoms sa akin sir CVT at sir kevinworld ,, lately nag search ako s honda u.s. forum lumalabas nuetral safety switch nga ang dahilan kya walang crank whatsoever, at available ung parts ,, ,, sa casa kc dito sa atin kung ano ano ipapapalit sa iyo dun ,,pero hindi nila babanggitin nila ung parts na yun .eh sa u.s. nga do it yourself lang ung pagpalit at paglinis nila nun ( pede nga plang linisin lang ). tingin ko kc un ang dahilan ng no start sa mga sasakyan nmin ,, sa ngayon ang ginagawa ko P-R-N-D-N dahan dahan lang hindi nagmamadali at it works for me everytime and press the brake pla. i wonder kung may nka experience ng magpalit dito sa pinas at kung knino nagpapalit ,ty sir
    25.8K:shazam:
    Aug 2012
    eto nga pla picture ng nuetral safety switch for honda fit , i think pede din ito sa city natin ( i guess lan po ). o bka mayron tayo available sa pinas ,, ty
    Aug 2012
    Where Is the Neutral Safety Switch Located
    By: Don Bowman
    Where is the neutral safety switch located? It's actually easy to find. The neutral safety switch prevents the engine from starting unless the transmission is in park or neutral. The switch is wired between the ignition switch and the starter. When the ignition switch is on, so is power to the switch, but when the vehicle is in a gear other than park or neutral, the switch creates an open circuit. When the ignition switch is in the start position, no power is transferred to the starter.
    On vehicles with a conventional neutral safety switch, the neutral safety switch also acts as a back-up light switch. The neutral safety switch on late model vehicles remains the same as it has been for many years. This is for the majority of vehicles, but not all.
    The switch, regardless of its form, needs to be in a location where it can contact the parking pawl or shift linkage. The most common is a
    By: Don Bowman
2008 Honda City idsi cvt A/T
