Results 1 to 10 of 12
- Aug 2007
- 42
August 1st, 2010 05:23 PM #1Bale dati yang umiilaw na yan madali lang mawala. after kalikutin ng mekaniko napansin ko matagal syang mawala, as in ilang minuto hindi katulad nung dati na segundo lang.
Ano ba to mga bossing? Hindi kasi mastart ang kotse hanggat di nawawala yan eh.
Salamat po sa makakatulong.
heto po pic
August 1st, 2010 05:36 PM #2
"Check Engine Light" or CEL. Merong sira makina mo at ipa check mo yan. Kailangan mo ng "reader" para malaman kung anong sinasabi ng computer na sira. Sa casa lang yan meron. yung reader.
- Aug 2007
- 42
August 1st, 2010 05:44 PM #3
August 1st, 2010 05:51 PM #4
Baka yung kinitkit ng daga, kung dati hindi ka namamatayan at hindi lumalabas ng matagal yung CEL.
- Aug 2007
- 42
August 1st, 2010 06:02 PM #5
- Nov 2007
- 39
August 7th, 2010 12:33 AM #6Mag start yan kahit hindi pa namamatay yung check engine light. Parang SOP lang na hintayin munang mawala yung check engine light. Try mo minsan start nang hindi pa nawawala yung check engine light mag start pa rin yan.
- Jan 2010
- 12
August 7th, 2010 09:09 PM #7paps, it's not advisable to start the engine while the CEL is on. When you turn the key to II talagang iilaw ung CEL for five seconds. tapos mawawala na sya. kapag tumatagal na ang pag-ilaw nya, there's something wrong na with your engine. try mo na paps dalhin sa trusted mechanic.
- Jan 2009
- 163
August 8th, 2010 09:40 PM #8sir ,
pa diagnose mo na lng sa shop na meron nito or sa honda casa para malaman mo kung saan ang may diperensya. mura lang naman iyon eh.. or hanap mo yung DIY sa check engine light meron din dito search mo lang.
Thanks sana makatulong.
- Jun 2010
- 76
August 8th, 2010 10:26 PM #9sir d mo naman kailangan hintayin mo mamatay yun CEL pwede mo naman start ang engine kahit may ilaw yun CEL tapos mamatay din matapos ng magstart yun car tapos magsystem check siya tapos pagmeron siya sense na sensor M/F saka iilaw yun CEL habang start ang car..ang ibig sabihin nun kailangan muna check sa sa auto technician..sir kung sa ngayon ay wala naman CEL ay ok ang system ng EFI mo wala po kayu dapat ipagalala.. sana makatulong sayu
- Oct 2009
- 6
September 18th, 2010 01:40 AM #10pare, try mo dalhin yan sa servitek. may reader sila na computer at makikita nila agad dun via codes yung problem. Hindi trial and error ang sistema nila dun kaya mas ok. Sure ka na yung tamang pyesa ang aayusin or papalitan nila.
high idle RPM at engine start
