honda civic 1999 A/T oil leak under the transmission?
mga sir saan kaya sya meron leak? mga magkano labor and parts?
saan po best magpagawang nito?
tnx
tnx
rock_kebab,
the best answer would come from the person inspecting for leaks. if the oil pan hasn't been removed before, places with tendency to leak would be the input shaft seal, drive axle seals, speedometer drive seal, shifter shaft seala and the breather. it is better to wash the suspected area with a suitable degreaser like simple green and flush with water. then drive about 5 miles and recheck for leaks. the servo caps on the side of the transaxle have that tendency to leak too. you can also add a luminous dye into the trans oil and check with a black light(ultra violet light) similar to the ones used in the clubs that make false teeth glow in the dark.
jick
Check mo iyong ATF fluid level mo sa dipstick kung nagbabawas . Mas maganda kung masilip mo kung itataas sasakyan sa shell service station para makita mo kung sa gilid at gasket kailangan palitan . Kung gasket problema bumili ka na lang at pakabit mo na sa kanila at pa linis mo iyong filter sa loob ng transmission . Palit na tuloy ng Atf Mura lang naman labor sa shell service station.
