Results 1 to 6 of 6
    mga sir's, i have a problem po sa vtec3 ko, nagbabawas po kse sya ng langis pero wla namn ako nkikitang oil leak, kakapalit lang dn ng gaskets and lahat ng oil seals pinalitan din, pero everyweek pag chinecheck ko ung dipstick nababawasan sya kaya weekly ako nagdadagdag lage ng oil, ano po kaya problem nya?sana po matulungan nyo po ako, thanks po.
    May 2009
    may usok ba sa exhaust mo?
    if meron kahit kaunti either sa dalawa lang yan
    worn change valve seals
    worn piston rings
    equals gastos
    Quote Originally Posted by vtis View Post
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format & grammar.
    Read the RULES.
    Ignorance is NOT an excuse.
    Repeated offenses will lead to banning.
    [/SIZE]
    No visible oil leaks means the leak is in the cylinders. Could be the piston rings.
    A compression test can tell you if there is a problem there and which cylinder too.
    Fixing it will be costly though.
    may nakikita akong white smoke sa exhaust ko, then pag nirerev mo sya may lumalabas na konting tubig, valve seals and piston ring?may idea ba kau sir kung magkano pagawa nun? thanks po sa mga reply nyo...
    May 2009
    eto mga kelangan mo:
    1. Piston Rings - Piston Rings installation labor, Dukot Overhaul, more likely ang labor pa lang nyan 5k di pa kasama rings mga 2-3k
    2. Cylinder Gasket - 1k - 3k from ordinary to carbon and steel type
    3. Valve Seals - Wag ka kukuha ng NOC na nasa banig, buy the noc high durable valve seals cost around 125-200 per piece kung 16 valve ka 16 pcs.
    4. Machine Shop Labors - Valve Rephasing, Valve Seats
    5. Labor again from Top Overhaul
    6. Misc. Items (Gaskets, O Rings, Seals, Change Oil)
    7. budget around 20k... nag paganito ako lately sa aking daily driver na ESI kakilala ko ang mechanic inabot ko lng lahat 15k including machine shops...
    MAGASTOS tlga yan kasi yan ang tinatawag na BLOWBY Engine
nagbabawas ng oil
