Planning to get a used 2007 crv 4x2. What are the common issues i need to look out for?
Sent from my C6802 using Tapatalk
All of the generations tend to be reliable, although, the 2007 model can have some issues. I suggest you check the power door locks, air-conditioning, and the automatic driver's window for any possible malfunctions. You should also check the tyres, since they tend to wear out quickly. If you have taken / plan on taking it on a test drive, check for any rattling sounds or loose parts.
Other than that, try to look at the maintenance records to see if it was well taken care of in the past. Should that be the case, the car should not have any major problems.
Timing chain na ba ang 2007 crv? 2.0
Got my crv earlier today, everything was functioning well. The owner misplaced the sparekey. Planning to have it duplicated. Can i start the engine using duplicate key from the mall?
Question regarding 2007 crv electric power steering (EPS)
While i was parallel parking my crv, the steering became harder to steer and the eps light comes on and off. Have you guys experienced this on your crv? Should i be worried?
kaya na ng Mr. Quickie sa mall iduplicate ang transponder ng immobilizer. I think it cost 3.5k if I am not mistaken.
Hello Honda lovers, need your thoughts about possible solution to my 2010 CRV automatic problem, the vibrations during idle is really getting noticeable now. done pms for 95k last nov.
Nakakairita na yung vibration at P or N or D (stop by breaking). Thanks in advance.
yung 2007-2010 pwede po ba lagyan ng 3rd row seat? kasya ba yung galing sa honda na katulad ng sa pic or pang 4th gen lang yun? thanks!
Sa mga naka Gen4, may nag upgrade naba sa inyo to a bigger battery? Group 24 daw ang upgrade and papalitan yun tray according to crvowners website. Eto bang Group 24 ang equivalent ng 2SM na size locally?
Na try nyo na po ba magpalit ng generic stabilizer link sa inyong CRV Gen2 na mabibili sa mga automotive repair shops. May kamahalan sa casa * P2k/pc as against P750 sa automotive shop?
Worry lang kasi ako baka hindi ito magfit properly.
Salamat po.
No worries it would fit...This is the only parts aside sa serpentine belt ang napalitan ko sa Gen2 ko...so far its been 4years na and I think time for another replacement. To me this parts are not that critical in case it would fail so I just settle for a replacement. Other like Brake parts and belts need ko Orig for mind assurance.
Hi Fellow Tsikot People,
Im eyeing this 2014 CRV as a second car for my wife. Can anyone identify if this a Japan CBU. And can anyone tell if this unit has an econo mode and push start. Actually haven't seen the unit yet. Thank you in advance!
