Results 1 to 4 of 4
    Feb 2010
    sabi po kasi sakin pa top overhaul ko na ung makina ko, kasi may symptoms na mag overheat na xa (almost reaching redline) lalo na pag natakbo ako ng 100mph pag naka patay naman po aircon eh ok nmn xa, and ok namn ung radiator ko according to radiator experts. regularly maitained po pag oil change ko. almost every 5 months palit ako and prang nde nman po nababawsan langis meron lang po parang nakatok sa makina ko lalo na pag naka 1st or 2nd gear lang ako o kaya pag galing sa pagdaan mula sa humps.. ano po kaya ma ssuggest nyo mga sir? i badly need your tips po first time ko lang kasi to car and gusto ko tlga matuto about cars.. nde ko rin gusto ung ingay kasi sobrang ingay ng muffler kahit naka idle lang XD thanks in advance po mga sir.
    Apr 2004
    never ever let a freelance mechanic do a top overhaul on your honda.
    your honda's engine components are precision machined by computers... hindi yan toyota 4K na pwede i-field strip agad agad!
    besides, top overhauls sa honda ay usually just a waste of money. magastos na, hindi pa babalik sa dating andar ang kotse mo.
    i suggest that you replace the following muna:
    1. engine thermostat.
    2. radiator thermoswitch.
    3. radiator cap (baka may singaw)
    both are cheap lang, install and observe. you are overheating at wide open throttle (wot) because there's not enough cooling to be had by the engine block.
    if those don't solve it, try having your radiator pulled down and overhauled (actually mas cheaper and better to buy surplus radiator na lang... 1,500 lang may kasama pa fan sa banawe).
    simpleng problem lang yan... hindi pa top overhaul yan. unless maghalo ang tubig at langis mo, ok pa yan... pag naghalo na... well, i advise you to just buy a surplus engine na lang kasi bottomless pit ng pera pag ginalaw mo makina ng honda at hindi mo alam ginagawa mo.
    yung tunog pag galing sa humps suspension mo yun. punta ka servitek pacheckup mo, it's either the engine mounts (3 yun) or yung front suspension mo.
    Feb 2010
    galing mo sir! ung overheating problem sa cap ko lang, ung tunog sa engine mounts nga daw..bago gawa lang din kasi front and back suspension ko, pati shock abs bago din spring lang nde. kano ba alam nyo pag pagawa ng engine mounts? pra lang may idea ako pag pinagawa ko na baka kasi tagain na nman ako, kagaya nung dati dinala ko sa casa 25k breaks, rock end, at minor repairs lang ginawa nde ko na sasabihin iba baka manghinayang kau eh hehe.
    Apr 2004
    sir, mahal talaga sa casa. sa edad ng mga civic natin (i own a 97, 99 and '03) di na advisable magpagawa sa casa UNLESS engine problem yan, in which case, dapat sa casa or sa specialista.
    last time i heard na may nagpalit ng engine mounts para sa esi sa officemate ko eh... parang nasa 3K ang isa, replacement yun. ok naman daw, once lang sya nagpalit sa 7 years nagtagal sa kanya yung kotse. parang 8K yata sa casa isa nun eh... eh tatlo...
    o kaya magpa-fabricate ka na lang... sa cruven/zee suspension rebuilders parang gumagawa sila nyan, polyurethane ang gamit. di ko lang alam kung magkano.
Mga sir help po sa 1993 honda esi ko
