Results 1 to 13 of 13
    Feb 2011
    what is the different of honda sintetic oil and the honda mineral oil..mas mahal di ba? sintetic is 2000plus but the other is 800 something..
    the Q is if dati gumagamit ako ng sintetic then i change it with mineral oil may magiging problema po ba..
    Jan 2011
    Quote Originally Posted by atog View Post
    wala. it's all myth. but if your car has a high mileage, use synthetic oil instead of regular (mineral) oil. it will give more protection to your engine especially when the engine gets hot(er).
    Quote Originally Posted by LNopal View Post
    Down grading may not have a problem, but upgrading for a high mileage car has potential issue. But not a guarantee naman.
    Jan 2011
    can you explain why?
    Synthetics (because they are really good) can free up some old sludge/deposits in the engine. They may cause this minor leaks in the head gasket area for example. You might want to read, http://www.carbibles.com/engineoil_bible.html
    Jan 2011
    i don't understand understand the statement :
    Perhaps not that common an occurrence, but worth bearing in mind nevertheless.
    it seems like the author is not so positive about his statement. is it a myth?
honda engine oil different
