Results 1 to 12 of 12
    Apr 2011
    Sir tanong ko lang bakit po kaya tumataas ang temperature ng kotse ko kapag uphill? My radiator got overhauled last month lang... Feeling ko tuloy hindi maganda pagkakagawa... Pinacheck ko na sa mechanic wala naman daw singaw ang head gasket! Ano po kaya possible reason bakit sya nag ooverheat?
    Feb 2011
    Sir, maybe you need to check if fan is working, baka hindi na umiikot because of thermo switch problem or fan relay, or fan mismo
    Apr 2011
    Nakarekta na po ang fan ko, malaks naman po ang ikot nya.. Pansin ko kapag paahon lang talaga tumataas ang temperature nya...
    bro.maliit lang kasi radiator ng honda.kaya pg downhill or uphill sa long drive bigla sya na taas pero,balik uli sa normal pag patag na..ganun ata pag old model na yun oto..IMO..
    Apr 2011
    Try ko magpalit ng 2 rows radiator... Pasok kaya pang toyota? Palitan ko nalang ng bracket?
    un 2rows rad. nalang ng pang honda accord much better bro.subok na yun.
    Apr 2011
    Quote Originally Posted by alcapone View Post
    Sir any idea magkano ang radiator ng accord?
    Jan 2011
    Quote Originally Posted by shejuliano619 View Post
    napalitan na ba yung water pump mo? maski na gaano kalaki ang radiator na ilagay mo, kung palyado yung wp, mag-overheat talaga ang makina mo.
    also, don't use tap water in your radiator. use coolant instead; you have to flush it every 2-3 years to remove residue. using coolant will also hinder the corrosion of your radiator. and if you're buying a radiator, make sure it is brand new. kung may mga tapal na iyan, chances are, mawala uli yung mga pinangtapal due to heat.
    Apr 2011
    Quote Originally Posted by LNopal View Post
    Wala naman leak ang water pump... Paano ba malalaman kung sira?
    Jan 2011
    merong 2 water hoses (black) (1) from the engine to the radiator; pag bukas mo ng hood, makita mo agad ito. (2) from radiator to your engine, nasa ibaba ito. run the car to warm it up, turn on the A/C to propel the fans when the engine hits the right temp to activate them. once these fans are activated, touch, i mean hold the upper hose and see if it feels warm (not hot or too hot). then do the same on the lower hose. if the lower hose is cold, your water pump is not working properly. time to replace it. and when you're on it, replace the drive belt as well so the repair will only be done one time. good luck.
    Aug 2009
    Baka stuck up na thermostat mo due to kalawang and age.
    Dec 2007
    Quote Originally Posted by micvel View Post
    + 1 same nangyari sa akin ... tried replacing thermostat and thermoswitch.. problem solved.
Help civic dx 1200 tumataas ang temperature kapag paahon!
