Results 1 to 3 of 3
- Nov 2008
- 6
February 28th, 2010 07:46 PM #1Mga sIRS.. nEED HELP PO KUNG PUED..
I just bought recently a Honda Civic '98.. The problem I think are.... My power steering fluid keeps on leaking.. di ko makita kung saan galing yung leak, sbi nung isang mekaniko sa steering hose lang, sabi nmn nung isa sa steering rod or oil seal lang.. Ksai ang lakas mgbawas eh I would fill it up in the morning then on the next day nasa low level na... next is I have a 17 inch rim, low profile tires, kaso kapag example dadaan ako sa may bridge at yung bridge ay may parang umbok kapag medyo mabilis ang dating ko may tutunog sa right front wheel ko na "bog" sound.. Ano kaya yon? Pero occasional lang nmn kasi kapag medyo di maganda yung road syempre considering na 17 inch mags medyo matagtag talaga, nakacoil over na ako eh pero hindi ko ni lower yung kotse pero sa right wheel lang nmn yung tunog na yon... Lastly, I need a new pair of CV joint. kahit surplus, which is ok bilhin, how much din po?.. Hope you could help me.. Im from Zambales...pls.. Tnx. Godbless..
March 1st, 2010 10:00 AM #2
CV joints are not that expensive. when i replaced mine it was 800/per piece (you need 2) brand new replacement.
leaking power steering dapat na ipagawa yan. pa-underwash mo muna tapos next morning paangat mo ulit tignan mo kung san galing talaga. duda ko jan yung oil seal, may repair kit nun pero libo din, pagawa mo na lang mekaniko marunong ng power steering system. PUT HONDA PS FLUID ONLY pagka gawa. wag ka gagamit nung nasa gas station you'll break the whole system.
yung sound na naririning mo pag nalulubak could be one or both of these things: suspension bushings or yung tie rod and rack end joints. pagawa talaga yan. expect maybe 5,000 cost sa repair, pagawa mo na both sides sa front.
- Nov 2008
- 6
March 2nd, 2010 08:11 PM #3Sir anu po brand na mganda sa CV joint? Tska po sir dito sa olongapo wala po akong mabilihan na PS Fluid ng Honda, Sa MAnila po kaya, san me puede makabili?
Tsaka po sir ask ko na din po kung mgkakaroon po ba akong problem kung dinadagdagan ko lang muna ng hindi PS Fluid from Honda kasi po hindi ko pa napapagawa eh.. Thanks po talaga...
Latest mileage:
