Results 1 to 7 of 7
- Mar 2015
- 34
July 28th, 2020 12:20 AM #1good pm guys
pa advise naman po
i do have ph16 vtec and gusto i upgrade ng konte ung engine
mechanic advised to upgrade box / camgear / headers
unahin ko sana 421 headers and camgear
will there be a significant diff. if nag upgrade ako nang ito munang 2?
or mag ipon ng sabay2 na lang
aabutin daw ng 30k lahat pati ung box
salamat po
- 54,293
- Mar 2015
- 34
July 28th, 2020 12:47 AM #3
July 28th, 2020 01:23 AM #5
July 28th, 2020 09:44 AM #6
Keep the car stock and use it as your daily driver. Less head aches and less maintenance cost than swapping a more powerful engine. Costly din engine swap because you have to change LTO documents, change the clutch, and also upgrade suspension (no amount of engine power is useful if you can’t keep all wheels on the tarmac). Not to mention dealing with all kinds of engine error codes.
Save the money to buy a more capable car. Maybe get an Evo or WRX as these are designed to be sporty in the first place.
July 28th, 2020 10:54 AM #7
Changing Air Filter
Changing Headers
Older guys like me will keep the car as stock as possible, then have it replaced by a newer car later.
I'm honestly not sure if your car is a 5th or 6th Gen Civic...
Before you increase the power... Think about your goals... Are you trying to be as fast as modern cars? Straight line or stable kahit sa highway?
Tama yung suggestion earlier to bring it to a shop with a Dyno, para makita mo muna yung power na available pa sa car mo.
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
