Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    May 2013
    Need your help mga master..anu kaya problema ng city kpag hard starting? Sabi un daw battery pero ok nmn ung busina. Hindi ba kapag mahina or problematic ung batt maapektuhan din dapat o hihina ung busina or it's not always the case? Automatic po ung kotse and as expectd ok kpag isineries ung batt (kc syempre tumaas ung voltahe)..maari kaya na starter ung problema? Kung sakali magkanu kya aabutin pagpapagawa? Btw, 51K na ung mileage..tnx mga sir.
    Kung umandar ng nakajumper cable. Battery yan.
    you have to diagnose it carefully... start with the battery.
    just a thought, i had a friend with the similar model ng city mo.... same problem... ignition coil ang problem.
    May 2013
    Quote Originally Posted by [archie] View Post
    Yes sir umaandar kpag nkajumper cable..ok nmn po kc ung busina malakas pa rin tlaga..un nga lang 4click minsan pra magstart..minsan nmn 1 click..concern ko kc bka starter. Tnx sir.
    May 2013
    Quote Originally Posted by 1D4LV View Post
    Tnx s input sir..magkanu nmn kya parepair or replacement ng igntion coil? Iba po ba yan s starter? Sorry noob pa po s auto.
    Quote Originally Posted by RafiTriya View Post
    not sure kung magkano sa labas. pero alam ko inabot ng 18k yung sa kaibigan ko sa casa eh.
    anyway, diagnose muna mabuti.... i am not saying na ignition coil yung sira nung sa iyo.
    Ignition Coil Failure Symptoms
    http://www.doityourself.com/stry/6-s...coil-failure#b
    Starter Failure Symptoms
    http://www.ehow.com/how_4845780_spot...d-starter.html
    Our 09 City A/T does not have this issue yet....
    But our mileage is still below 20KKm, and we have not yet changed the original battery.
    21.8K:bike3:
    Jun 2004
    Iba pa yung ignition coil sa starter, starter problems are usually for much older cars, repair would probably cost around 1k if the problem is with the starter solenoid.
    In my case with ignition coil problems usually the vehicle would not start anymore until you replace the coil, around 2k yata bili ko dati pero ibang model ng kotse.
    I would start by having a battery shop check the health of the battery.
    May 2013
    Thanks mga sir.. Battery po una ko suspect pero since ok nmn ung busina at ilaw s panel, im thinking bka hindi battery ang problema..so i thought better ask for opinion muna bka meron n dito nakaencountr ng gnitong issue.. Kung starter man ang prob, any idea how much would it cost for repair or replacement.
    ganito yan eh....
    start ka muna sa battery.
    tapos check mo yung spark plugs and high tension wire.
    tapos check mo yung distributor.
    tapos starter.
    tapos tsaka pa lang yung ingition coil.
    kung repair lang naman ng starter, mababa lang yan..... baka mga nasa 2k lang yan the most.
    ang yes, by having your horn and dash lights working does not mean to say na ok pa ang battery. the battery needs around 13volts to start-up. the horn and the dash lights can function even if the battery is below 5volts na lang.
    Jul 2011
    ang EFI engines ba may high tension wire at distributor (cap) pa rin?
    ^^ yes, meron.
    Quote Originally Posted by s10pao View Post
    Yung mga modelo ngayon na efi wala na distributor or high tension wires. AFAIK, city 09 does not have distributor or high tension, fly by wire na.
    Sep 2012
    I'm noob din sa kotse but I'm more in electronics. With sir 1D4LV's comments, pwede mo TS (RafiTriya) tap a voltmeter sa positive(+) and negative(-) terminals ng battery. Ask a person to start-up the engine while you're checking ano minimum voltage pumapalo sa voltmeter.
    ganito yan eh....
    tapos starter.
    in addition to this, it may have ample voltage but does not have ample amperage. kaya hindi na kinakaya ng husto ung cranking ng makina mo.
    my suspect is the battery. have it (1) checked by motolite - free of charge and (2) if it is still good, have it inspected by electrician - might be an alternator issue or connection issue of poor charging.
    dami pa sir possibilities pero yan alng naman mga basic niyan. and it is better to start with the basic, it is free anyway.
    i had same problem kaso namamatayan din ako ng makina non, so baka magkaiba tayo problem.
    May 2013
    Quote Originally Posted by TopEngine View Post
    Naku sir, wla po ako voltmeter..pero anu po ba dapat minimum voltage? Dapat ba nka idle lang or need i-rev ung makina?
    Jul 2011
    ung nga rin ang alam ko, pero ayon kay 1D4LV meron daw...
    Jan 2009
    Many 90's and earlier EFI vehicles still use the traditional distributor cap+high-tension wire ignition system. Newer cars have replaced that with individual coil packs (one for each cylinder).
    Jun 2006
    Kung hindi mo pa napapalitan ang battery mo, 4 years old na yan. AT ang kotse mo. Palitan mo na ang battery. Mga modelong kotse lalo na pag automatic malakas dapat ang battery. May experience ako, isang araw ok one click ang kotse, next day ayaw mag start. Kahit redondo wala. Malakas ang busina at ilaw. Pinalitan ko ng battery. Ok agad, one click.
    Masyadong bago pa ang kotse mo para mag ka problema sa starter o ignition coil. Halos sigurado ako na battery ang problema mo.
Hard starting sa Honda City 2009AT
