Results 1 to 2 of 2
    I have my A/T honda civic vtec vti 98 model.correct po ba u model name?..
    my prob. is about the transmission..yung para bang alam mna dpt mag shift xa lgi late..and pag uphill grbe slow andar nya hirap xa galit na makina ayaw parin mag shift..
    Lahat bago na,,the atf,tuneup,change oil,fule filter change..
    Pero about s ATF po pala kasi sabi ko paki linis yung oil fan po ba yun,edi inangat u auto ko sa machine nila wala daw ako oil fan pinakita sakin..wala po ba talaga oil fan u ganun n model.nakita ko lang yung para labasan ng fluid nya pag drain mana u ATF,u parang knot dun.
    Then kapag nasa garage ako sa haws parang pigil u andar ko pag ni rerev. ko cia..
    advice name po sa inyu ano gagawin ko sa auto ko..espcially girl pako wala ako alam sa auto..
    May 2007
    Probable Causes
    1. Vacuum leak on engine
    2. Dirty throttle body
    3. IAC motor defective
    4. Poor electrical connection to the IAC value
    5. Many more
    Those are only probability and yet you best option is to have your car check at casa the on board computer to find out the code. The on board computer on your car registered all the problem it encountered by your engine. Good luck.
help po..about transmission
