mga sir, curious lang ako kung ano po ang top speed ninyo sa inyong car(civic matic 97).... kasi I can only go to about 120km/hr... may technique ba para tumaas pa top speed ko? tnx po mga sirs...![]()
before i sold my stock vtec matic late 96, it can easily hit 150kph in north e-way, may fear na 'ko to go higher than that, kaya di ko sure if it can go higher still. something must be wrong sa unit mo sir, pa check-up na lang po siguro sa reputable mechanic. i dont have a good answer sa second question.
i had a 1996 civic vti a/t na ek, umabot ako 165kph highest hehe, mabilis ang civic pero ang ayaw ko talaga is the jerky automatic transmission lalo pag 1st to 2nd gear..parang may tumutulak sa buong sasakyan hehe
i also have a 96 ek a/t vtec. i can easily boost my speed greater than 120kph. if am driving at NLEX i can go farther than 150kph pero, di ko na binibilasan pa minsan kasi natatakot na ako .......
it's better that u should bring ur car to a good mechanic to check it.
Top should be around 170-175... maybe 180 if you turn the AC off.
Don't ask how I know.
*mikey_civic: What do you mean: you can only go 120 km/h? Do you mean it doesn't accelerate anymore after 120?
While the wisdom of actually doing much more than 120 on a public road (unless it's the NLEX or Skyway) is highly debatable, the Civic should be capable of much more. Does your transmission slur on take-off (from a stoplight)? Or does it feel very heavy or sluggish? An AT VTi ain't no stoplight racer, but it should accelerate positively and smoothly from a stop (until it *jerk* shifts gears...).
If it doesn't, check your ATF for bubbles and/or metal shavings, and have your transmission checked by an honest mechanic (a slightly-less-than-honest one will just tell you to buy a new transmission, whatever the problem is).
But I doubt you have any major problems... if you did, you wouldn't be able to accelerate past 60-80 km/h.
naka-125 to 130km/h ako sa north e-way pero hindi ko pa sinasagad yung gas nyan. i'm sure kayang-kaya pa ang 150km/h if i wasn't thinking about safety concerns...
i have a civic LXI 96 A/T. I can go beyond 140 km/h sa NLEX. I travel a lot from San Fernando exit to Angeles exit. Palagay ko kaya nya pa hanggang 160 kph because I didn't try to push the car into its limit. Maybe sometime
