Results 1 to 13 of 13
    Hi guys, what do you think of the Honda Integra? Regarding it's part availability, durability, comfort ride...
    I think of getting one to make it as a spare car pag lumalabas ako mag-isa... any other car would you recommend?
    350T ang benta, is it a fair price?
    Thanks
    Its a nice 2nd car. Anong year model yan? Atsaka bakit ang mura?
    Dec 2007
    Which year model is this?
    Mechanicals should be easy to find. It shares its guts with the popular EG Civics, and parts for the engines are usually easily acquired at a surplus parts shop.
    Check the chassis code
    DC2 ba?
    DC2 ba?
    last time I check sa net, it is 2000 model look, but the CR says its 2004.. imported maybe may pagkakaiba sa registration.
    Headlight is bilog pa. The engine I asked is 1800, SOHC... the newer integra is 2.0 DOHC yata.
    If I remember it right.. .parang d18 or B18 ang engine... tama po ba ako?
    Can you post a pic?
    Sarap i mod nyan... :D
    Quote Originally Posted by Dudee View Post
    I think it's the DC2.
    check the chassis code. (chassis number sa body or registration)
    B18 engine yan.
    Pero may variants yan.
    B18B (hindi VTEC) and B18C (VTEC)
    If it's the B18C, mas ok yan
    Lalo na if it's the B18C5 (Type R)
    Dec 2007
    Teka, SOHC na 1.8? Hindi B18 yan.
    I doubt a 1.8L SOHC engine even exists for any Integra. It's either a SOHC 1.6L ZC or the aforementioned B18 DOHC 1.8L.
    wala SOHC na B18
    B18 is DOHC,
    meron VTEC, meron non VTEC
    Quote Originally Posted by Type 100 View Post
    I will check again.. hehehe... di kasi ako kabisado sa mga kotse..
    Btw, B18 engine... is it the same with other honda engine? Baka mahirapan ako mghahanap ng parts in the future.
    The integra from the front looks nice, pero di to type ang tail lights nya... hehehe
    Any other comments regarding the integra? San tayo makahanap ng mga bodykits at accessories nito ?
    Jan 2009
    buhayin natin ang thread na to . i personally loved integras . based on it's looks , lalo na ung bilog pa ung headlights (dc2 ba yun?) . parang ang sarap kasi nya i mod based on performance . imo this car is built for tuning than ricing ! , another plus factor is coupe siya at masarap ipang race !
    Jan 2009
    i found this information useful, sa wikipedia, search niyo nalang b engine.
    B18C (Type R)
    • VTEC
    • Found in:
      • JDM Honda Integra Type R
        • Power: 201 hp (150 kW) * 8000 rpm
        • Rev-limit: 8,700 rpm
        • 134 ft·lbf (182 N·m) * 7300 rpm
        • Transmission Type: 5-speed standard with LSD
        • Displacement: 1,797 cc (109.7 cu in)
        • Compression:y 11.1:1
        • Bore: 81 mm (3.189 in)
        • Stroke: 87.2 mm (3.433 in)
        • Rod Length: 137.9 mm (5.429 in)
        • Rod/Stroke Ratio: 1.58
        • Transmission: J4D (96specR w/ LSD)N3E (98specR w/LSD)
    B18C1
    • VTEC
    • Found in:
      • 1994-2001 Acura Integra GS-R (DC2,DB8)
        • Compression: 10.0:1
        • Bore: 89 mm (3.189 in)
        • Redline:8100 rpm
        • Power: 170 hp (127 kW) * 7600 rpm & 128 ft·lbf (173 N·m) * 6200 rpm
        • Transmission: s80
    B18C2
    • VTEC
    • Found in:
      • 1994-1999 Honda Integra VTi-R
      • AUDM Spec 1993-1999 Honda Integra VTi-R
        • Compression: 10.6:1
        • Power: 167 hp (125 kW) * 7600 rpm
        • Torque: 128 ft·lbf (175 N·m) * 6200 rpm
        • Redline: 8200 rpm
        • Fuel Cut: 8300 rpm
        • Transmission: Y80 (No LSD) 5-Speed Manual Transaxle
        • 0/100km/h : <7.3 seconds
    B18C3
    • VTEC
    • Found in:
      • 1995-1998 Acura Integra Type R
    • Powe: 193 PS/189 hp (141 kW) * 8200 rpm & 127 ft·lbf/172 N·m * 7500 rpm
    i dunno nga lang if locally available yung parts nya dito sa pinas. sana nga meron . does anyone know or rather sinong may integras na napamod or tuned dito sa tsikot ? btw im new here !
Honda Integra
