Results 1 to 9 of 9
    Jan 2011
    Guys, hirap mag start after ko ihataw yung hatch ko. Pinalitan ko na ng fuel filter. Fuel pump ok naman daw. I need opinion guys. TIA
    Have you checked the ignition system for problems including the ignition coil?
    Jan 2011
    Hindi pa po sir. Pero nag start naman yung engine, kaya lang biglang namamatay. Kung ano ano na gusto papalitan saken ng mekaniko. Relay na naman daw ngayon. Try ko po pa check yung ignition system n coil. Thanks po.
    Apr 2004
    original engine ba yan? ph12 carb?
    if so, there could be a problem with your carburettor. nalulunod sa fuel kaya hirap mag start. or may singaw na.
    have the carb overhauled muna... mura lang to sa kamias carb shops. tapos i-tune nila yung timing and then go to honda to get the valve clearances adjusted.
    unless tumatakbo ka ng palyado, i don't think there's problem with your ign coil. maybe the spark plugs (fouled) or high tension wires meron ding biyak. these are worth checking na din while the carb is disassembled and you're just sitting there waiting.
    Jan 2011
    Quote Originally Posted by voltscastillo View Post
    The engine is d15b vtec sir. Fuel injected. Maganda naman po yung takbo ng car, it's just that pag ihataw tapos pag pinatay na engine dapat pag pahingahin bago sya mag start ulit. Mag start sya pero mamatay din agad engine. Need opinion guys. TIA
    Aug 2010
    sir check mo rin ung servo linisin mo n rin...
Hard starting after tumakbo ng mabilis. Honda hatchbak
