naka harness na ang headlight ng honda vti 96 pagbili ko.
plano ko mag hid.
need pa ba hid kit or hid bulb na lng??
plano ko mag hid.
matanong ko lang idol ano po ba ung harness na tinatawag..
ito ba ung retofit projector...
kasi ung sa akin HID lang walang harness kaya medyo sabog ang buga..
+1
harness refers only to the "wiring" upgrade (+ relays & ceramic sockets) - which can 'stand' a higher BULB wattage.
if you want HID, get the set/kit
1. Ballast (check wattage & housing - dictates na price, eg slim ballast + higher wattage)
2. Bulb (if H4, meron Hi & Lo parehong HID, meron din Hi - halogen, lo - hid)
temp:
3000k -4300k yellow
6000k white
8000k bluish white
* and up (purple?)
with this rainy season, a good pair would be yellow on fogs + white hid (kasi bulag ka sa ulan+asphalt road)
Advantage naman sa projectors: buo ang bato at hindi sabog (kawawa kaming mga kasalubong mo in case)
hth
projectors hindi lang advantage, its a must.
pag walang projectors dapat hindi gumamit ng HID.
hindi rin basta naka projector eh ok na gumamit ng hid, imho meron 2 types of projectors, 1 is designed really for hid &
the other type of projector is designed for halogen bulb used, this type of projector will still give glare to the incoming motorists when installed with hids..to solve this glaring issue the projector must be retroffited to give a proper cut off..hth
Tama! Pero dapat maganda rin yung aim ng projectors. Naka-projectors nga taas naman ng aim.
Tsaka meron din mga projectors na cheap lang... minsan mas panget pa yung buga neto sa stock reflector bowls. So, halogen ka nalang kaysa mag-pilit ka ng HID + cheap projectors Hehe
to wrap this up..ano po ba magandang hid?specific details?gusto ko yung lumalaban sa may nakasalubong na hid.kc nakakabad trip na hindi mka laban yung stock lights ko.tnx mga master...
ano nga ba ang average life span ng mga hid?
iyong sa amin kasi stock/oem hid ng fd and after almost 6 years it's still doing fine
meron din akong civic, siguro sir, mag philips xp or xv kanalang or osram nightbreaker. yung HID pang porma lang naman yun, mag HID kanalang sir kung meron kang SUV or mamahaling sasakyan, tingin ko lang sir
basa basa ka dito para sa mga bolt-on projectos na ok.
http://tsikot.com/forums/car-lights-...jectors-76939/
Gen5 yung gamit and ok naman siya. kung mas mataas budget marami pa mas maganda. mababasa mo na rin diyan mga ok na bulbs.
and please, wag gumamit ng plug and play HID na walang projector.
