Results 1 to 8 of 8
November 1st, 2009 04:02 PM #1
mga sir and master, follow up ko lang tong thread dun sa thread na pinost ko,
ETO YUNG FIRST THREAD KO "mga sir tatanong ko lang kung ano kaya problema ng AC ko...kasi mahina yung AC nung tsinek ko, malamig yung hose nya...di kaya leak yun?di ko napacheck kasi maiksi lang bakasyon ko..."
Ngayon naman di na daw nagana ang A/C, nung gagamitin daw nila di daw gumana yung A/C, ang nangyari kasi nadiskarga ang baterya kasi bihira magamit pinakargahan at nagstart naman daw lahat gumana pati AC pero may naamoy sya na parang sunog pero hinayaan lang nya, tpos kanina nung gagamitin na di na gumana yung AC. ANO KAYA PROBLEMA NITO?
Compressor kaya or stock AC sya?Advice naman mga sir kasi papadala ko na sa kasa eh baka kung ano ano ang sabihin at ipabili sa asawa ko...
2008 City mga sir ang kotse.
November 1st, 2009 06:28 PM #2
Sounds like a toasted compressor clutch coil or a/c blower motor, depending on where that bad smell is coming from.
It was never mentioned if the blower still worked after the bad smell.
November 1st, 2009 11:07 PM #3
working naman daw po sabi ni misis kasi, ginamit daw nila yung car pero naka off ang ac kasi mahinang mahina tlga daw ang lamig pero may lamig daw...take note, "may lamig na mahinang mahina"
November 2nd, 2009 12:02 AM #4
In that case, it could be a simple matter of leaking freon. There might be a slow leak somewhere. Unfortunately the leak could be anywhere. If its on the coils or tubing, the fix will be cheap but if the leak is the compressor, it will be expensive to fix/replace.
The car will need to be serviced in an automotive A/C repair shop. If you have one that you trust, tell you wife to bring it there.
- Oct 2009
- 12
November 2nd, 2009 10:21 AM #5
November 3rd, 2009 10:20 PM #6
Sabi ni misis, ok naman daw lahat ng fan, duda ako yung sinasabi na amoy sunog yun yung mga stock na tubig sa drain nya....pinadala ko sa casa to check, sinabi ko na check yung mga belt kung may mga torn belt at yung compressor bigyan ko kayo ng feedback kung anong mangyayari....
salamat at sa uultin mga sir
- May 2009
- 38
November 19th, 2009 09:10 AM #7bro may lamig ba yung aircon mo pero mahina yung buga ng hangin??
ganyan din nangyari sa car ko, car ko crv n 2nd generation, nasa biyahe ako nun nung bigla ko napansin na humina yung hangin pero may lamig pa rin. chineck ko ung makina nakita ko yung akin yung tubo yung sa aircon nag iice na. yung case nung sa akin barado yung evaporator.
ano na balita sa auto mo?
November 21st, 2009 04:34 PM #8
OO sir may lamig na mahinang mahina pati yung hangin....
ganun din dati yung AC ko nung binuksan ko yung hood while the engine is running...sobrang lamig ng hose....
Awa ng dyos sira pa din....ayaw pagawa ni misis baka daw kasi magoyo sya ng pagpapagawaan...
*sidney yung sayo kamusta na AC nang sayo?nung barado ang evaporator sir?ikaw na lang ba naglinis or dinala mo pa sa casa?
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
