Hello tsikoteers!
I have a problem with the ignition switch problem of my Honda Civic 96. Following is the summary
- I can start the car.
- I can drive the car.
- I can still pull the key out o the ignition switch key hole (nasa "I") nga lang naka-point yung part of the key.
- The problem is, I can't move the key-hole back to zero (0) to totally turn cut some of the electrical circuits (...?). Matigas na siya..
Following is the actual position ngayon na naka-off siya.
I removed the battery connector para maiwasan na ma-discharge. I already tried spraying the key hole with WD40 but to no avail.
Any ideas? Any idea how much it would cost me to repair or replace this part?
Thank you!
