Results 1 to 20 of 20
    Ano po kaya probema sa oto ko esi m/t, pag nag load ako ng accesories e.g. headlight, switching power window, especially aircon eh bumababa yung rpm ko ano po kaya problema nito. TIA!!! Banzaii
    Apr 2009
    Quote Originally Posted by slomo View Post
    I have the same problem sa esi ko.
    Need advise as well.
    sir pag i off m yung aircon bababa pa rin yung rpm?
    di kaya sa "minor" yung problema? try mo i-adjust. screw-like yun.
    Try mo install grounding kit sa kotse mo . Malaki improvement nito sa lighting system , performance baka makatulong ito lalo na sa may problema sa idling.
    Jan 2008
    hi,
    i am not sure if anyone experiences this same problem. i have a 97 city mt.. my rpm is okay, i say 90% of the time.. kaya lang, there are instances wherein babagsak nalang ung rpm ko ng sobrang baba to the point na halos mamamatay na makina ko, siguro nasa 100rpm lang..this only last for about a few seconds, probably 10-15 seconds lang... it does not happen all the time.. it happens whether naka aircon ako or not..
    for example, tumatakbo lang ako ng normal then i come to a full stop, that's the time na bigla nalang babagsak rpm ko.. so minsan kapag bumper to bumper or pag magbabayad ng toll... do you guys have an idea on this case? i don't experience this everyday... may mga certain times lang talaga.. thanks!ü
    Sir ganun din ung problem ko, explain naman how to install grounding kit, saka anu ba yung mga parts nun... tenks
    Quote Originally Posted by tedboydboy View Post
    hi,
    na try nyo na ba magpa throttle body cleaning? ganito kasi ang sign sa ek ko pag madumi na to the point na mas dadalas na yung pagbaba.
    Feb 2005
    Quote Originally Posted by n5110 View Post
    [SIZE="2"]+1[/SIZE] on this. I'd like to think na incidentals lang yung electrical-related observations. When the issue is idle drops, when at start normal naman sya, it is likely a dirty throttle valve.
    Have it cleaned by a guy who knows how for if not done properly, ganun pa din mangyayari afterwards.
    Jan 2008
    ahh i see... mabilis lang ba gawin yun? so that i will know if i can do it during a workday or weekend nalang.. and, do you have recommended shop/mechanic within alabang or las pinas?
    Feb 2005
    I had my C220 done before and it took a couple of hours. At least 2-3 hours if I'm not mistaken.
    I had it done at my friend's shop in QC. I'm not so sure of a particular shop to recommend to you at Alabang/Las Pinas area. Maybe some guys here could chime in for a recommendation.
    Mar 2005
    try nyo din po pacheck yung alternator
    yup. try to check din po alternator. sometimes yun po ang problema. Mahina na supply ng kuryente. Sir, any shop na affordable palinis ng throttle body at change belt na din at adjust ng timing. My car is a Honda VTEC3. Baka may alam po kayo. Ok po ba sa honda spa? or any shop na suki at ok po. thanks.
    Aug 2009
    try din po pa check ung sa servo..kc i had that kind of problem before..and when i had it done ok na.
    buhayin ko lang to..same question din kasi ako...
    kakakuha lang din ng 95 civic ESI m/t, 2nd owner na ako, lately pag start ko sya napalo un RPM nya 1.5k ng hindi ako naapak sa gas pedal, tapos nababa...then pag natakbo na okay nman..pero may time na pag nasa traffic naglalaro un idling nya, its either tataas or sobra baba naman na halos mamatay na... ano kaya problema nito..hindi naman kasi ganito nun nakuha ko sya eh. gusto ko lang makasigurado, daily commute ko kasi pque-tagaytay-pque. salamat sa reply mga sirs.. had it checked by a mechanic bago ko kinuha, verdict naman nya sulit at well maintained yung car. any advice would be greatly appreciated mga sirs..
    Apr 2009
    ^^Up dun sa grounding kit and alternator...
    I had this very similar problem before sa d15b and mas madalas and evident yung idling rpm change niya pag naka-aircon... and it was solved:...
    • Had my AC compressor belt and alternator belt change (dehinds pa kaya bumili bagong compressor and alternator eh)...
    • Installed a grounding kit (mas mabilis magstart and umakyat yung power window, kahit sabay naka-on yung radio at aircon)
    • Cleaned the servo and yung area directly going to the throttle "butterfly" using 3M carb/injector cleaner
    • Adjusted yung menor
    • Used STP Fuel Injector Cleaner and Vortex Gold (medyo parang may knock kasi pag XCS eh)
    Ayun, oks na siya. Hindi ko lang sure kung dun sa mga pinaggagawa ko yung nagsolve sa problem...
    Apr 2009
    ^^Up dun sa alternator...
    In my case, the culprit was the belt kasi talaga naman sobrang worn out na. Tagilid na nga ikot nung pulley eh.. Which made me think kaya hindi na fully optimised yung alternator, which in turn hindi na din nagrerecharge ng maayos yung battery ko.
    There was even a time my batt was totally discharged, damn the alternator belt... And syempre ako din... I shoulld have hecked and replaced first thing upon knowing it...
    Aug 2009
    try mo palinis servo and ung throttle body..or palitan spoon filter and o-ring.Had that problem before.ngaun ok na. and kasama na din dun adjust ng menor.
    Apr 2009
    Quote Originally Posted by jyro06 View Post
    Sir jyro san ka nakabili ng Spoon filter?
    Drop-in lang ang Spoon filters diba?
    Aug 2005
    your best bet is throttle body cleaning and ground kit. try it first before going to the alternator.
rpm falls down
