just to compare lang po.hehe.. and to give me an idea when it needs refilling.
dapat di kailangan ng refilling. kung nauubos, ibig sabihin may leak yung system mo. ideally, you only charge it pag nagpalinis ka nang aircon. once a year i suppose.
i bought my sentra in 1997. until now, aircon still cools well. never had to refill the freon. my 5 year old innova recently had its freon refilled.
it shall never deplete. if it does it has a leak in the system. do you refill the refrigerant in your ref every year or two or 5 years. also, a perfectly working air conditioning system should never be dismantled otherwise it will be exposed to foreign objects if not serviced in a dust free room/area. if you have a brand new vehicle, never have the aircon system cleaned after 3 years or 5 years as long as it is working perfectly.
sir ask ko lang nag-evacuate ba kayo sa innova nyo bago mag magrefill?
ask ko din refrigerant R134a capacity ng innova?
our 3 yr old innova no problem sa cooling kaya lang parang short cycling (7 sec engage 7 sec disengage * 23-24C AC settings)
at sa sight glass may bubbles sa buong cycle ng engage ng clutch
--tia
pag wala namang leak, walang reason naman yan para maubos.
i think the longest for me was around 3 years.... kasi on the third year, kailangang palitan yung evaporator.
13 years then 5 years, only had to re-add freon due to leak from evaporator and lately from the expansion valve.
