Results 1 to 8 of 8
    Dec 2011
    Hi guys, I've been reading these forums for quite some time and this is actually my first thread post. Have any of you tried Yokohama services? I've been planning to get my car checked since this car haven't checked for ages. They have this promo at Ensogo for Complete Wheel Alignment (TOE and CAMBER) + Free Preventive Maintenance at P699.
    Details:
    - The Complete Wheel Alignment is for the Toe and Camber.
    - Preventive Maintenance
    Included in the Preventive Maintenance are the following:
    1. Break pads thickness on all 4 tires
    2. Break pad operation on all 4 tires
    3. Brake Rotor inspection on all 4 tires
    4. Tire tread depth on all 4 tires
    5. Front upper and lower ball joints on both front tires
    6. Bearings check
    7. CV joint check
    8. Lube job for suspension and steering components (Gear Oil)
    9. Lights operation (brake light, headlights, running lights, reverse lights, turn signals, dome light(s)
    10. Windshield wipers, Windshield washer fluid, check Radiator fluid, check Transmission/ Clutch fluid, check Brake fluid, check Belt, check Leak, check Air filter, Check Tire Balance, check Alignment, Pre-requirement Check up - (Tire Rod, Rack End, Etc), Computerized Alignment Diagnosis - Front and Rear Tires Battery and Battery Cable Overall driveability (Test drive with mechanic/authorized personnel)
    Also included are Free Nitrogen Tire Inflation and Tire Rotation
    Any feedback on Yokohoma Malate, Manila Branch? Your replies will be highly appreciated!
    Sep 2005
    for 699 eh mura na yan..
    Jul 2011
    *TS, sir tanong mo naman sa Yoko kung magkano lahat kung walang discount
    Sep 2005
    nakalagay don sa ensogo eh Php2,650.00
    Dec 2011
    P2,650.00 ang Original Price daw. Check nyo yung sa Ensogo. Unfortunately di ko maopen dito sa office. Blocked. Kunin ko na din. Bayad na lang ako sa 7-11 later.
    Quote Originally Posted by s10pao View Post
    Aug 2009
    I.m planning to avail of this too on my SUV, but my is question is how do you know when is the time for your vehicle to undergo complete wheel alignment?
    Jul 2012
    wow ang mura! last time nag pa alignment ako it cost me 700+ sa minerva westgate dito sa may alabang. do they offer under chassis rin kaya?
    Nov 2004
    sayang ended na yokohama promo * ensogo! request natin magkaron ulit parang 100 vouchers lang nabenta e. Sulit to at 699, ang camber/alignment usually nasa 2.5k, pag alignment lang 250... E yung promo sa ensogo may free nitrogen pa lahat ng gulong at tire rotation, pati greasing ng mga fitting free.
    http://www.ensogo.com.ph/manila/yoko...-11122012.html
    Always feel safe and secure by preventing accidents through a Complete Wheel Alignment (Toe and Camber) with Free Preventive Maintenance and other freebies.
    The Complete Wheel Alignment is for the Toe and Camber. This and Preventive Maintenance improves your vehicles reliability and prevents costs of possible future repairs.
    Also included are Free Nitrogen Tire Inflation and Tire Rotation.
    Bearings check
    CV joint check
    Windshield wipers
    Windshield washer fluid check
    Radiator fluid check
    Transmission/ Clutch fluid check
    Brake fluid check
    Belt check
    Leak check
    Air filter Check
    Tire Balance check
    Alignment Pre-requirement Check up - (Tire Rod, Rack End, Etc)
    Free nitrogen tire inflation
    Free tire rotation
    Redemption period: November 28, 2012 to February 28, 2013.
    Vouchers may not be combined.
Yokohama Wheel Alignment and Maintenance
