Results 1 to 20 of 27
    Sep 2006
    if wala pong all power,anong model ang magandang i set-up?
    Sep 2005
    If I'm not mistaken, walang all-power na EG hatch. Kung gusto mo, mag-EK hatch ka na lang. Marami nyan sa Cebu and meron din few here in Manila. All power sya. Search mo EK hatch dito sa tsikot.
    Personally, I'd rather just add the power steering, locks and windows to an orig LHD unit, than convert the steering of an all power unit.
    Pareho naman silang conversions at the end of the day. hehehe.
    Aug 2006
    of the local EG hatches, wala atang lumabas na all-power na stock.
    all-power was reserved for the EG sedans. madali naman pakibatan yan ng power features. pinakamahal lang yung steering. that would set you back around 10 to 15k.
    Sep 2006
    about the steering,hindi ba magiging hassle if converted? then sa window naman,may nakita na kung pina-power window pero pangit.yung pindudan sa tabi ng CAMBIO nilagay.
    I don't have experience with Hondas. But putting PS systems on Benzes and Lancers is not rocket science.
    Mas malilito pa ko dun sa paglipat ng gearbox, rack and pinion, steering column, pedals, etc. associated with steering conversion. Pati brake master ililipat. Magpapabend ka pa ng bagong brake lines, etc. Siguro it seems painless because the vehicle has been converted already when you acquire it. But its hard to be assured of the quality of the install since you did not see it being installed and you'd have to do a major teardown to check things.
    Yung nasa shifter kasi it eliminates the need for a master control panel since both switches can be reached from the driver's seat. Ganyan din set up ng Eurocars (Bimmers, Volvos, MB's, etc.).
    You can acquire the correct parts but it may get expensive since most LHD power window controls available in the market are for 4 door models. You'd also have do redo the door panel because there will be a hole where the window winder was and you need a place to put the switches on. There is a plastic blanking plate available for the winder hole, I'm not sure how you're going to place the switch, though.
    Oct 2005
    magandang set up, is a local car nga as what OTEP said, tapos lagyan mo na lang ng JDM power windows galing sa mga surplusan...
    Aug 2006
    madali lang ipapower steering and windows ang EG.
    wala namang kasi yun. hihina lang ng konti yung hp mo dahil sa power steering, but shouldn't be a big problem.
    as for power windows, kuha ka na lang ng Gathers na interior. Complete na yung with semi-bucket seats, sidings, and powerwindows. 2-3 hours lang kabit na lahat.
may honda hatchback bang all power from model 92-95?
