Results 1 to 19 of 19
    Mar 2005
    Meron po bang may idea o may alam kung magkano gagastusin ng pagpapakabit ng B16 sa Civic LX EG including labor and parts at san shop?
    mahal ang B16 ngayon eh... i think going rate is around 50-55k, engine only, meaning wala pang tranny, brakes, etc. usual install cost ranges from around 15-20k. add 5-10k for miscellaneous expenses.
    just set aside a 100K to be sure.. tsaka baka pag andun ka na baka gusto mo pa magpaturbo hehehehe
    Dec 2003
    B18C nalang...hotcake msyado ngaun..270k makina pa lng hehehe
    hahaha.. baka ayaw na magchange engine niyan sa sinabi mo hehehehe
    Dec 2003
    haha pero baka kasama na tranny cguro nun hahaha
    lsd tranny ba un?.hehe.. wag na.. kung ako.. d15b pus turbo :D para hinde ganun kalakas sa gas..
    Mar 2005
    270K!? Isang 96 VTi na tsikot na ri yun..I think i'll stick w/ the stock engine nalang..
    Feb 2005
    r_2gue mag turbo la na lang..
    Mar 2005
    Di ba may internal modification pag nagpa-turbo ka?
    Aug 2004
    yah, if you want it to last...
    forget turbo, though... just get the swap. 100k is about right, and should cover everything, as long as there are no complications.
    niky,
    kahit ba tamang boost lang nakakasira din?.. hinde ba oks lang naman?hehe
    Dec 2004
    whew, mukhang mahal na ang b-series ngayon, three or four years ago b16a was going for 35K with tranny, b16b for 75K...maybe scarce na talaga
    if you're interested in going all-motor, why not look at the k-series? maybe you can check if the k20A (fitted on the 200hp 2.0 civic type R) is available locally or has been imported.
    if you're into hybrids, b-series options would be a b20 block (2.0 li displacement) with the b16/b18 head, or for the k-series the k24 block (2.4 li displacement) with k20 head...but i digress
    Aug 2004
    My friend from banawe knows someone who sells a k20 Type-R engine complete with tranny, suspension... it'll cost you 300k... a perfect mod for a JAZZ!! Lipad un sigurado ;)
    Aug 2004
    but i don't think it'll fit the EG body... it's just for the ES,EP3,Jazz/FIt... bka sakit lang sa ulo un pag nilipat mopa sa EG. just go for a b16EG. sakto ito sa EG civic mo
    Dec 2004
    yup, the k20-in-EG would be very challenging...aside from the above mentioned, pwede rin sya sa EK Civics (96-00).
    Mar 2005
    Pero read from honda tuning magazine.. hasport has a swap/mount kit for K20 into EG Civic.
    Aug 2004
    K20s are still too expensive secondhand. I'd go for a B16A for minimum hassle.
    And, yah, odell, even with moderate boost, you can mess up the engine... if your mechanic has no idea what he is doing.
    currently ay nagsa shopping ako ng engine to swap sa aking eg. right now ang jdm D15B vtec 16valve ay nasa $600, B16A1 naman ay halos $1.4-$2k ang presyu...ang C5 ay ubod din ng mahal.
    So mas murang bumili sa pinas imo...lalo na sa mga banawe and sa imus. siyanga pala engine swap daw ay hindi naman mahirap gawin...kahit first timer ka ay 2 days lang tops.
    i am planning on doing a swap very soon kasi napurnada ang camshaft ng civic ko and replace ko na rin ang engine.
    D15B with turbo ay ayos nga daw sa dami ng naririnig ko. so far kapag ndi ako nakakita ng good B16 ay mag D15B na lang ako.
    And yeah mahal ang B16A lalo na pag kumpleto... pero sa Pinas mura lang cguro ang labor kahit dini ay about 10K pesos lang ang engine swap sa mga Mexicans
Cost: B16 on Civic LX (EG)?
