Results 1 to 6 of 6
    Jun 2010
    before di nman to ganito, usually one click lang yun starting nito pag pasok mo ng key tas twist start na agad...
    but now pag start ko.. parang pumupugak at di tumutuloy sa starting..kelangan ko pa bombahin ang gas para tumuloy siya mag start.. pls help mga sir... newbie on cars lang po. salamat ng marami
    Jun 2010
    any one care?
    Have you tried getting the engine's throttle body cleaned?
    When was your last tune up?
    Replaced the sparkplugs recently? (correct gapping?)
    Are the high tension cables in good condition (no cracks)?
    Aug 2006
    pwedeng starter ang problema or a weak battery na. try to check isa isa para malaman mo yung pinaka cause
    barado na fuel filter?
    Jun 2010
    thanks sa reply mga sir... last tuned up was march, battery was changed september... dont know if how old na mga spark plugs,, oansin ko lang yun high tension wire may konti parang ngatngat ng daga.. would that affect the starting?
Paps help... ano kaya problem ng honda esi matic ko?
