I just want to know how much would be my budget if i will to convert my rear drum brake to diskbrake. my car is civic EK 99.
any shops po doing the convernsion?
thnaks in advance...
5.5k to 7.k ang set ng disc brake kung sa bodega ka ng shop ng surplus ka magagawi lalo na kung kadadating palang minsan kasama pa pati ang arm, shocks at spring.
tapos ang kabit 1.5k isang pares na yun pero kelangan mo rin bumili ng isang boteng malaking brake fluid for bleeding.
canvass ka na lang sa banawe at evangelista marami naman mapagpipiliang shop dun pero kung sa banawe ka lang gagawi punta ka sa sprint tapos tanong mo kung saan ang bodega ng surplus nila kasi mura daw silang magbenta.
bale ang shop nga pala nila sa banawe cor. agno bale autoservice shop nila yun hindi sila mismo yun hindi sila gaanong nagbebenta ng surplus dun.
sir boy tino matagal ba paglagay ng diskbrake.mga ilang oras kaya? wla bang disadvantage sa pagconvert? thanks sa replies...
Mga Bossing may alam ba kayo na bilihan ng cable ng rear disc brake pang EK? May disc brake kasi binigay sa akin pang ek kaso walang cable hanapan ko na lang daw...any idea kung magkano and saan makakabili? TIA![]()
aejay17 actually my only purpose of the conversion is pamporma lang. no other else. so basta maayos lang pagkalagay then no disadvantages... anyways thanks for the replies...
Hello Jun,
In my opinion meron advantage ang disk brake kesa drum brake. One is that you have better gripping power because is has bigger precise brake contact surface.
You will feel the big difference when your are braking on wet weather, Even though ang rear brakes are secondary brakes that actual meron actuation lag sa front, it has a significant effect. That is why in performance cars, they use all disk brake.
BUT if you will only use you car on on cruising and everyday drive...the stock drum is already ok. But if you have the chance to feel how a good grip brakes,
go for the disk. Also buy the original nissin pad...be sure that the disk brakes set is OEM , specifically made for your model car.
Happy Motoring...
HONDA OC Plus / Salev Racing
mga sirs, can you recommend shops for me to buy rear diskbrakes. Yung shop na merong ng magkakabit.mga how much kaya.probably bear paranaque or las pinas. thnaks
subukan mong mag inquire dito.
http://www.sulit.com.ph/index.php/li.../m/technocraft
*rai711 try mo sa casa or sa mga surplusan for sure meron yan hand brake cable...hth..
subukan mo rin pala mag-ikot sa cavite bandang imus at bacoor tiyak malapit sa inyo yan at ang presyo mas mura pa ng pa sa banawe at evangelista, may mga kakilala kasi ako dito na nagsa-surplus yun mga kakilala nila dun minsan ay nag aahente sila dun.
sya nga pala cavite na ngayon ang kilalang bagsakan nga japanese surplus car parts.
