Results 1 to 5 of 5
    Jan 2013
    Pafs pwede ba gamitin ang TB nang pang Matic sa manual?
    Nag loloko kasi idling nung civic ko pag binubuksan Aircon pero pag wala ac ok naman., bumababa ang idling pag bukas ac na parang nag hihingalo minsan pag cold start na mamatayan pa sa sobrang dip nang idling pag bitaw sa gas, na try ko na palinis ang TB and IACV ganon padin,
    meron ako isa pang TB kaso pang matic. Nung try namin ikabit ok sana pag tinapakan ang gas pag bitaw steady agad hindi nag didip kaso ang taas nang menor pag wala ac 2k pag naka on ac 1.5k tapos minsan bigla mag tataas baba idling from 1k to 2k.
    Quote Originally Posted by man524 View Post
    Imho sira sensor nyan boss at pagkakaalam ko 3 yan just replace one sa suking parts supplier. Pagpinabayaan mo aabot tama nyan sa ecu
    Sent from my GT-I9300 using Tapatalk 4 Beta
    Oct 2009
    pwede naman ung pang matic sa pang manual..baka naman sa linya hindi gumagana ung idle up niya,,
    Quote Originally Posted by jaypee10 View Post
    I agree. Check idle up
    Jul 2013
    Cleaning the IACV and throttle body will not solve the problem unless na-tune din niya and said parts and re-align the timing. After that you have to bleed the water lines also just to make sure there's no air on your lines pagtanggal ng throttle body.
Idling problem civic vti d15b MT
