Results 1 to 4 of 4
    Dec 2009
    mga bossing.....
    nee ko help nyu.... bibili sana ako ng 2nd hand na jazz....
    matic with 7 speed mode..... ayus ba yan??? o may prob ba eto???
    07 model...
    Bago pa iyang 07 model Jazz na bibilin mo at wala naman problema sa modelo na iyan . Check mo na lang ang kundisyon ng makina pinaka importante sa lahat at magsama ka ng mekaniko na bihasa sa modelo na bibilin mo para wala problema.
    Iyong automatic transmission ng sasakyan dapat maayos at swabe ang pagshift ng gear kung magkasira man ito malaking gastos . Isa pang impotante iyong legal na dokumento ng sasakyan kung saan nakarehistro. At iyong iba maayos pa naman siguro iyan depende na rin sa gumamit ng sasakyan . Kung maayos naman lahat ang nabili mo proper maintanance na lang iyan para tumagal buhay ng makina mo at sasakyan.
    Jan 2009
    Just want to note that this model uses a CVT transmission. Do NOT use ATF. Only use Honda CVTF.
    Aug 2004
    The most important things to look for on a secondhand CVT are the actual condition of the unit and the service records. If, on the test drive, the CVT feels too sluggish or slips a lot when hot, walk away. Best to bring someone familiar with the Jazz/City CVT with you so they can tell you if the behavior is normal or not.
help pls [buying 2nd hand Jazz 7-speed]
