Results 1 to 11 of 11
    Oct 2009
    bkt ganun, i followed the steps kung pano i-reset yung ECU, pero pagka disconnect ko ng negative terminal, pagkabit ko uli, naga-alarm yung kotse. honda civic vti 97 model po ito.
    may mali ba o normal lang un?
    Feb 2009
    Quote Originally Posted by bobochan789 View Post
    bobochan,
    most factory alarms and some aftermarket ones do that. you need to disarm the alarm first and leave the power locks unlocked before you disconnect the battery power. reconnect with all switches to ignition and accessory in the off position.
    jick
    Dec 2007
    I think normal lang yan sir. Narereset din yung alarm. Same din sakin nung namatay na yung car battery ko at di na kaya icrank yung engine, everytime na iistart yung car nagaalarm so parang pag naputol ang electric supply nung alarm nagaalarm sya.
    Oct 2009
    haha salamat mga sir, normal lang pala yun, so far maganda ung pagkakareset ng ECU ko, parang gumaan yung kotse, gumanda din yung idle nya!
    nga pala, pano naman yung so power locks ko, yung isang lock ng door hnd naglolock kahit ilock ko from driver's lock. kaya kelangan mo pa syang ilock manually talaga. pano nagagawa un?
    Sira na siguro yung actuator nung isang door lock mo.
    Oct 2009
    sir pinapagawa ba yun or pinapaltan lang? saan kaya pwede?
    Depende sa sira. Pa-check mo nalang sa mga auto-electrical shops, baka naman may naputol lang na wire.
    Oct 2009
    ok sige sir! babaklasin ba yung pintuan nun?
    Dec 2007
    either the actuator or yung link (metal rods that connect the lock to the actuator). sa link pwede naputol or kumalas lang
    Baklas pinto yan.
    Aug 2009
    Out of topic po siugro to, pano po ba mag reset ng ECU at bakit sya nirereset? at para saan ang ECU?san makikita to sa kotse?
    Honda City A/T '08 po yung kotse...
disconnected negative terminal, nagalarm yung car ko!
