Page 1 of 27 1234511 ... LastLast
Results 1 to 20 of 527
    Aug 2007
    Hello Guys sorry for the long waiting anyway I'm back to answer your question about your Honda Problems just sit back and relax just bear with me for the late reply. ;)
    Anyway actually Mechanic, Electrical, Body Paint & some referrals in my contact are still recommendable. The following recommendable and reliable contacts are as follows:
    Quezon City Area Only.!
    1. Honda Spa Mindanao Ave.
    - weather you like it or not you will always buy to a CASA Parts "but" if its only a repair kits, bearings,crank shaft camshaft, crank shaft pulley, engine support etc.. Rest of the parts can be bought to a replacement parts or surplus.
    - Mechanic - Alvin Auto Repair Shop
    # 51 Road 20 Project. 8 QC.
    Replacements
    - Fertes Honda Parts
    Japan / Taiwan / China etc..
    Location: Roosevelt Avenue Quezon City Infront of Alex Car Restoration or beside PMI College.
    - RODA Auto Parts
    Surplus
    Kaizen Roosevelt
    Location : along Roosevelt going muņoz left side near chinabank and metro bank look for the YELLOW Gate no signage but all of its parts are jAPAN chopchop. Kaya walang name it's a Honda underground heaven. Shhhhh.! Atin-Atin lang. Hehehe.
    Hope nakatulong ako. Anyway next time il answer your Honda Problem as soon as possible.
    HONDABOT.!
    Sent from my iPhone using Tapatalk - now Free
    Jul 2011
    boss san ok magpa-PMS outside ng casa? QC and makati area
    Aug 2007
    If you taking good care of your Honda. Mas maganda sa kahit saan Gas station Shell Service Center will do or Petron pwede mo pa reklamo kung meron ka napasin mali or pumalya takbo ng sasakyan mo. Mahirap kasi I called it sa bangketa mechaniko. Mura nga hindi ka pa masisigurado. ;) it's better to be safe 👌
    Aug 2007
    For those aircon problems I just repost the ever reliable car aircon repair shop medyo tago pero sulit.
    Re: Best Place Honda Parts & Services in Quezon City
    http://tsikot.com/forums/showpost.php?p=1464495
    Feb 2005
    Hi Hondabot, I've got a question:
    Everytime I drive thru a puddle or a part of the road with built up water, while the A/C is on, the battery indicator light would display.
    It disappears whenever I turn the A/C off. After I while when I start the A/C again, it's no longer there.
    Any culprits? City 2004 iDSi M/T.
    Thanks!
    Aug 2007
    Hi
    Try to check your alternator chief.! Or the fuse it might be wet or loose.
    Tip:
    Pag lumusong ka sa baha try to turn off your A/C.
    Jun 2013
    ano kaya ang cause ng high-pitched na parang wooo na sound tuwing cold start and malamig ang panahon? nangyayari lang pag gumagalaw ang kotse at very slow speed, pag nilagyan sa drive without stepping on the brakes and gas pedals. parang hindi rin belts since walang ingay pag hindi gumagalaw.
    Aug 2007
    Sparton
    Try to check your air valve intake it might be the problem. What year model and make.?
    Jun 2013
    2013 CRV. Is that something that needs to be fixed right away?
    Aug 2007
    Wow definitely go to Honda immediately to fix the problem. That's a SOP.! Good Luck
    Apr 2013
    boss my pricelist k b kung mgkano ung rs wing ng jazz 2013 tska pakabit... hehehe...
    Jun 2013
    I uploaded the sound here: http://vocaroo.com/i/s0mqvBgFKR6j
    Oct 2011
    Sir HondaBot,
    Meron po kaya sa Kaizen ng pipe na nagcoconnect sa headers at muffler? San din po ba ok magpagawa ng muffler?
    Palitin na daw kasi ung pipe. Thanks po!
    Sir Hondabot,
    Meron po akong City GM 2009 1..3 MT. I got it second hand, all stock, all original.
    Ang problem is laging nag flu-fluctuate yung headlights. pag nag-engage yung compressor humihina yung headlight for about 1 second then babalik uli to its regular intensity. Pa ulit-ulit lang yun basta mag automatic yung A/C compressor. Nilagyan ko na ng extra grounding wires and I've even managed to stuff a NS60 battery pero ganun pa din symtoms. I tested yung voltage while running ok naman minimum 12.68 volts pag na on yung A/C compressor. Ang hindi ko nalang ata nagagawa ay mag lagay nung voltage stabilizer gizmo (pero I have doubts if even it would make a difference) and mag palit ng alternator.
    Thanks in adv.
    Sep 2013
    Sir, honda city idsi sa amin. Last year napansin namin pag P to R, without stepping on the gas, aatras then pause saka tutuloy ang atras. Sabi sa honda cvt oil change lang daw. Nawawala naman pero after a while bumabalik ulit. Na observe namin na pag P to N then R wala namang problem. After one year, andun pa rin ang problem so nagpa cvt oil change ulit kami. After a few months bumalik ulit ang problem.
    After magpalit kami ng battery pinamanual calibrate namin ang transmission and nawala sya pero after a few months bumalik ulit. Walang problem pag normal driving na.
    Appreciate your advice. Thank you.
    Mar 2012
    Quote Originally Posted by jeremy.cruz View Post
    Most likely flywheel yan.. we had that same problem before, pinapalitan sa casa mga 18k inabot...
    Aug 2007
    In Kaizen they also install your mufflers concern
    Aug 2007
    Check it to Danny Hipolito Electrician he will advice kung ano ang problema re: headlights
    Aug 2007
    Sir Jeremy try to drop by Alvin's Shop at Road 20. Re. Cvt
    Aug 2007
    Quote Originally Posted by ban0y View Post
    Sir I have no shop I'm just a Honda Owner like you. I'm here to help Honda enthusiast to maintain our vehicle in top shape.
    Long live our Honda.!
    Hondabot
    At your service. 👌
I'm back Hondabot at your service
