Results 11 to 20 of 26
    Like old calculators...meron error cache/memory that stores those error codes.
    Jan 2009
    Quote Originally Posted by Wishing View Post
    Pwedeng idle control valve or pwede din shift solenoid ang nagloloko. Mahuhuli yan ng computer kung anong error code makikita nya.
    Walang ICV ang FD.
    Jan 2009
    Walang ICV ang FD. Tingin ko malabo din sa shift solenoid. A problem with the transmission won't raise your idle RPM and trigger a CEL. Kapag anything to do with the A/T, the shift position indicator(s) would blink.
    Apr 2010
    Quote Originally Posted by saksidriver View Post
    ^^ basta umiilaw na yan check engine light once, kahit mawala pa, Ma-de detect pa din ang error niyan kapag nag run ng diagnostics. So better na ipa diagnose mo na. Babalik at babalik lang yan hanggat hindi naco correct kung anong sensor ang may maling reading. Hindi porket nawala eh ok na. May error pa din yan na dapat ipaayos.
    Thanks sa sagot sir! Pupunta na ako sa shop ngayon.
    Jul 2012
    same thing happend with my honda jazz cvt at tranny. while driving i saw "D" blinking then umilaw check engine light.. hindi ko agad naitabi kasi pa u turn ako then ayun bigla hindi na umandar. pinatay ko makina then restart ok na ulit. i will definitely have my car checked this weekend.. i think it needs cvtf and change engine oil.. pero kinakabahan ako sa blinking "D" at baka sira na tranny ko.. lately kasi kumakadyot na sya while driving and may noise nko naririnig sa ilalim ng engine. sana umabot pa sa weekend.
    Nov 2014
    Quote Originally Posted by nashimoto View Post
    Boss nashimoto hows the repair with mel cabasa??? Nakuha ba??? PaFeed back sir....thanks
    Jul 2012
    sir arvin ok nmn po. bumisita ako kanina umaga.. tuneup at palit langis pati cvtf. although tranny na tlga, sabi sir mel ok pa at magagamit pa.. ipon lang ako for surplus.. pero matatagalan pa un. umaandar pa nmn.. just need to be more vigilant sa pag palit ng langis para maganda andar ng oto.
    Nov 2014
    Ah ok nga pala ako yun nakita mo dun kanina umaga.... Ako yun naka city at sumama sa test drive ng otto mo....
    Anyway magkano sabi ni mel sa tranny? Magkano aabutin sir???
    Jul 2012
    + / - 18k. pwede pa nmn oto ko.. bka next year nlng.. kung may pera na cge bro ingat. musta na oto mo?
    Nov 2014
    Ok naman medyo nag loloko lang idling/rpm pag mga 40-60kph taas baba tinginko yun IAVC problema or may vacuum leak sigiro pero di pa naman ganun halata....medyo maselan kse ko eh.... Cge par....ingatz ipon ipon ulet....
Check Engine/Malfunction Indicator Lamp
