Results 1 to 5 of 5
    Feb 2011
    ahm.nag change engine po kasi ako.pero parang sobrang lakas ng vibration ng engine..pero nka scub din ako..ang problem lang hindi nag activate ang vtec at mahina ang hatak ..ano kaya problema?
    Jan 2011
    Try to bring it back to the shop who did your car's engine swap procedure. Maybe it just needs a bit of tuning.
    Jan 2011
    Quote Originally Posted by jcner21 View Post
    Ano computer box gamit mo sir? And underpowered siya until it reaches 3k rpm,, kasi 12valve mode palang siya from 1-3k rpm
    Feb 2011
    po8 daw po kasama sa engine n box..hindi naman ako marunong tumingin kung ano ang box..
    Apr 2009
    *jcner:
    You can do it yourself.
    The computer box is located under the right-most corner of the dashboard, in the passenger foot well under the carpet matting.
    Carefully scarp off the matting and the ECU will surface with the serial codes facing you.
    Somewhere it the series would read a P** code.
    Yours should show a P08 if it is indeed.
change engine to d15b vtec does now work.
