Results 1 to 6 of 6
    Dec 2007
    Balak ko po sana magpalit ng rims from stock honda jazz gd what would be the recommended tire size and rim offset for the following
    wheel diameter na siguradong hindi magkakaroon ng rubbing issues on all ends.
    a. 15 inch : ___ Rims Offset / ___ Tire Width / ___ Aspect Ratio
    b. 16 inch : ___ Rims Offset / ___ Tire Width / ___ Aspect Ratio
    c. 17 inch : ___ Rims Offset / ___ Tire Width / ___ Aspect Ratio
    Note also that I might probably put lowering springs with max of 1.5 in drop in the future.
    Dec 2007
    hope someone can help me on my inquiry.
    Mar 2012
    pagaralan mo na lang din dito sir.
    Car Bibles : The Wheel and Tyre Bible Page 1 of 4
    Apr 2012
    the best rim and tire size combo for your honda jazz is no other than the stock
    asking for recommended offsets, widths and aspect ratios here in the forum are quite difficult to answer as not all are familiar with your vehicle.
    once you are decided to change your stock tires, what you can do,
    a. go to a tire shop
    b. select the rim design/brand and sizes you like 15", 16" or 17"
    c. select a tire brand you like, have them trial fit to your car, if no rubbing issues come up then that's the perfect fit...
    Dec 2007
    *stickers - thanks for site though it was not able to fullfill my inquiry.
    *monty_GTV - thanks for the advise but maybe i was hoping tsikot jazz gd owners can help me based on their experiences and current setup.
    this method is simply FAIL-SAFE.
Best Rim and Tire Size Combination for Honda Jazz GD
