Results 1 to 10 of 10
    Nov 2011
    Noob here Sir:
    Pressure plate, release bearing, clutch disc price and maganda brand po sana mga Sir.
    I want to replace my clutch assembly but dont know what is a good brand for my car.
    Reason for replacement:
    Wild RMP:
    Done cleaning AICV (servo) [same wild rpm problem]
    Spark plug and hi tension wire been replace (Ala dun parin problem) binalik ko stock hi-ten
    Clean distributor for carbon build up for continiuos electrical supply (same parin)
    Clean Throtlle body for carbon built up ( same parin wild rpm problem)
    Reset computem box as per procedure of HCP and tsikot furom procedure ( wild rpm parin)
    Sir need help na nataas na gastos ko para maayos po kotse ko.
    Kaya po ako napunta sa pagpapalit ng clutch assembly dahil isang co furomer na nagbigay ng payo sakin at ng isang tropa ko rin po. Pero need ko po sana ng tulong nyo mga Sir
    hmmm. wild rpm tapos palit ka clutch?
    baka hindi pa kailangan.. sliding na ba clutch mo?
    Nov 2011
    [QUOTE=1D4LV;2030489]hmmm. wild rpm tapos palit ka clutch?
    baka hindi pa kailangan.. sliding na ba clutch mo?[/QUOTE
    *sir 1D4LV siguro po kasi minsan po para tunog ng makina lang naririning ko at alang hatak. Gagawin ko bibitawan ko lang gas pedal tas dahandahan ko ulit tatapakan yun ayos na uli.
    My nakapagsabi po kasi sakin sir na baka nga clutch assembly na problem ko kasi sa mga sinabi ko na nagawa ko at andun parin wild RPM ng oto ko.
    Dami na po kasi gastos sa mga pinapagawa sir.
    Baka may idea ka na iba sir pa share naman po.
    [quote=jisantos;2030510]
    Quote Originally Posted by 1D4LV View Post
    have you tried the initial dagnosis for clutch failure like putting your gear in 4th, tapos bitaw?
    when was the last time you've changed the tranny fluid?
    pag akyatan ba sumasabityug clutch, hindi kaagad kumakapit?
    Nov 2011
    *sir 1D4LV
    Last June Honda change my clutch fluid.
    When i drive the car minsan mo parang slide xa tunog na lang ng engine then hindi sya natakbo ng maayos kung hind ko bibitawan yung gas pedal tas tapakan agad.
    Over haet po kasi engine ko nun so change ako cylinder head 1998 model eh 1996 yung akin pero maganda sya manakbo bo nun mga ilang buwan.
    This was happen i put some enchancement oil fluid daw para gumanda oil circulation sa engine. Yun pang tapak ko ng clutch bumabagsak na rmp ko reaching zero na nga.
    Nov 2007
    Quote Originally Posted by jisantos View Post
    Noob here Sir:
    Wild RMP:
    Try changing the computer box, I doubt the wild rpm is caused by your clutch system, but if your tranny is due for a change then might as well do it.
    Nov 2011
    Both are expensive. But 1st i will change my clutch assembly and if no affect to the problem that time i will change my computer box. Problem is i dont know where to buy and brand name of clutch assembly
    Sep 2010
    Quote Originally Posted by ans_lim168 View Post
    sir if you need a computer box meron ako para lxi gurranted yun dipa nabubuksan galing sa auto ko yun nagpalit ako ng d15 na engine kase.
    May 2009
    For honda buy FCC brand for clutch disc & plate. Release brg NTN,NSK,NACHI, or KOYO
    Nov 2011
    Quote Originally Posted by gerome View Post
    *sir gerome
    Magkakano po kaya yung FCC na brand ng clutch at pressure plate
Pressure plate, clutch disc and release bearing for LXi 1996 Honda civic
