Results 1 to 16 of 16
    Oct 2009
    Good day po sa mga tsikot members......
    I need your help guys in solving my problem on my 1999 civic... i bought it last month... the seller told me na may konting kalampag (tok tok sound) sa harap.. its easy to repair daw... sabi nya its just the stabilizer link and bushing... then for the last month na pinapaayos ko yung kalampag na yun d makita ng mga mekaniko kung saan nanggagaling yung tunog.. i have been to 3 shops pero bigo pa rin ako... they have changed a lot of parts na pero andun pa rin ang tunog...
    Sa umpisa when i drive the car wala naman cyang kalampag eh.. then after 10 15 min.. ayan na.. kahit na patag ang daan its making that tok tok sound... i dont know what to do na... please help!!!
    I havent tried bringing it to the casa.. masyadong expensive kasi pero sa mga ginastos ko na, sana dun ko na lang dinala...
    Mar 2007
    Quote Originally Posted by thravis_burn View Post
    Paano ang tunog nito?... pag tumatakbo ng paliko? o Pag medyo nalulubak?
    The best shops to bring it in is an Under chassis specialist since this is suspension related.
    Suspension specialists are ZAFRA and CRUVEN to mention a few. Kung ang mekaniko pang makina lang - maaring di niya makikita ang trouble niyan.
    My friend is a Honda Cars Specialist - in Kawit, Cavite... minsan may dinalang Civic - ganyan din ang problema... hindi rin makita sa ibang shop yung tumutunog. Nung dinala sa kanya - alam niya agad... may parang strut bar pala yan na maliit sa rear suspension - hindi ito halata from out side... you need to remove a rear wheel to see it if my memory serves me right. Yung Bushing nito, pwedeng mong palitan using original part - pero mahal...
    Kung sa Cruven - baka makamura ka, tapos - Polyurethane pa ang ipapalit nila... this is 15 times stronger than normal rubber - mabubulok na lang oto mo - di pa rin ito masisira basta laging gagamitin.
    Oct 2009
    Knocking sound cya sa front side... parang nakasakay ka sa kalesa... even patag ang daan ganun pa rin ang tunog.. parang nag tritriger cya when i make a full turn (left or right).. sa umpisa minor lang ang knocking sound nya pero after 10 15 min... lakas na... nakakairita d ba...
    So need kong mag hanap dito samin sa batangas city ng nag specialize sa underchasis..... madami nang napalitan na mga pyesa...
    thanks po sa reply........
    Ang dami ng shop na pinagpagawaan mo kung baga trial and error nangyari at hindi naman nawala iyong problema mo. Subukan mo munang angat ng jack ang gulong sa harap at paikutin mo kung may maririnig ka .Suggestion lang
    sir kamo natitrigger when you make a turn.. & since napalitan mo na lahat pang-ilalim.. i guess it's the Constant-velocity joints (CV joints). pag may tok-tok sound na when you make a turn, need na palitan po yan. ganyan nangyari sa lancer ko dati.
    Oct 2009
    Quote Originally Posted by redeemed View Post
    Sir meron po ba kayong idea of how much to change the cv joints? kasama na pati labor? tnx po sa info try ko na patingnan ang cv joints.....
    sir last may 2008 yun.. 2 pcs CV Joint - P2,600 + labor P400.00. dito ko lang pinagawa sa trusted mekaniko ko.. siguro kung ako mismo bumili ng parts baka mas nakamura ng kunti.
Help on my 1999 civic (tok tok sound)....
