Results 1 to 19 of 19
    Oct 2009
    mga sir nauubos lagi yung tubig sa radiator at reserve water ng honda esi 95 model ko anu kaya ang problema?
    napaoverhaul ko na yung radiator na palitan na din yung hose na nagcoconect sa makina pero nauubos pa din yung water anu kaya problema?
    thanks in advance
    May 2004
    check mo kung may leak sa may water pump... check mo din kung kulay coffee na yung engine oil mo? check mo kung may white smoke habang nag drdrive ka?
    Oct 2009
    Quote Originally Posted by 1997 View Post
    bagong change old lang po yun.. may white smoke pag nirerev po di ko talaga mafirgure out kung anu problem nya HELP!
    Aug 2009
    bro ive experienced this before,i dont know if same situation,nauubos din dati yung reserve water ko tapos yung sa radiator,pero i checked the radiator their was no sign of puncture,wala din leak, pina checked ko sa mechanic we found out na my tama na pala cyl head ko,doon pumupunta yung tubig,pinalitan ko nalang ng bagong cyl head,until now ok naman cya nawala na yung prob,just try to check lang..
    Oct 2009
    Quote Originally Posted by dark_akatsuke24 View Post
    napalitan ko na po ang cly head pero ganun pa din.. FYI sir, girl po ako..
    Quote Originally Posted by msklodset View Post
    Na palitan din ba ng cylinder head gasket .
    Oct 2008
    palitan mo ung radiator cap ng bago
    Oct 2009
    Quote Originally Posted by projector View Post
    napalitan ko na din po yung rad cap..
    hay i really need
