Results 1 to 3 of 3
    mga sir, jaz wanna ask if normal sa a/t esi 95 ang malakas na vibration specially kung naka aircon???if not...what could be the problem???nacheck na yung ecu, servo at engine support pero ganun pa rin...pati rin yung power steering ko po medyo matigas..napalitan ko na ng power steering oil at pump pero medyo matigas pa rin..what could be the problem..?balak kong ipacasa pero baka tagain lang ako e..NEED YOUR HELP GUYS.. THANKS!!!!
    Apr 2004
    are your engine supports original? or replacement parts? original engine supports do absorb vibrations much much better than "japan" or "taiwan" supports. orig ones are liquid filled, while replacements only have plain rubber bushings sandwiched together.
    have you tried checking your engine timing and valve clearance adjusted? you could also be running on 3 cylinders instead of 4, which could explain the vibrations.
    problema ko din sa ES ko yung matigas na steering. i'm guessing its an overly loose, or overly tight belt.
    Jan 2003
    of course too much vibration is not normal..just changed one of the engine mounts on my crv. i also experienced excessive vibrations, found out that one engine mount was busted. i used replacement brand, so far so good. now it's as smooth as silk.
too much vibratioon on a/t esi
