Results 1 to 8 of 8
    Good Day Gys,
    Im Wondering If Any Of Yo Experienced My Ordeal.... I Have A 94 Honda Esi, Aboght It 2nd Hand Last Year, Now Im Experiencing Problems On Starting.....
    Pag Ginagamit Ko Ito Sa Gabi With Open Aircon And Headlights, Pag Tigil Ko At Pag Bukas Ng Makina Eh Ayaw Umandar Pag Wala Aircon At Mga Headlights Ok Naman Sya Andar Agad.... May Click Sa Makina Pero Ayaw Mag Tloy Ng Andar, Sabi Ng Isang Mechaniko Mag Palit Daw Ako Ng Battery So I Did, After A Month Ganun Nanaman, Di Naman Sya Nag Overheat, Pero Humihina Yung Battery, I Boght 2 Batteries Na Tina Tap Ko Pag Ayaw Umandar.... Charging Kaya Ang Problem (alternator) Chinek Ko Yng Alternator Mukan Ok Naman Kase Ginamitan Ko Ng Tester Ok Naman Ang Voltage Na Lumalabas... Pag Andar Tinagal Ko Yng Negative Terminal Ok Naman Hindi Namatay Yung Engine...
    Sana Matlongan Nyo Me Kahit Pag Diagnose Lang Kase Balak Ko Bmili Ng Bago Starter Kung Yun Ang Problem... Baka Kase Pag Bili Ko Eh Magkaproblem Padin.
    Thanks,
    Markus
    Nov 2006
    tingin ko hindi naman totoo na pag tinanggal mo yung negative cable ay mamatay ang makina to test kung alternator ay sira na,lalo na kung bago ang battery,kasi pag tinanggal mo yung negative cable aandar at aandar pa rin yung makina,mamamatay lang yan pag nadischarge na yung battery.
    perform ka muna ng draw test at madali lang.used or new battery ay okey lang pero mas okey kung new or newly charged battery.
    kung meron kang volt/amp meter, iset mo sa 10 amps,tapos disconnect ang negative cable (kailangan off lahat ang accessories pati lahat ng doors ay nakasara at tanggalin ang susi sa ignition switch,pati trunk,except hood) at iconnect mo yung positive side lead ng amp meter sa negative battery cable,at yung negative lead naman ng amp meter sa negative side ng battery terminal.
    result;
    hintayin mong bumaba sa pinakamaliit na amperahe,palagay ko mga 20-30 seconds.dapat mga nasa .1-.2 amp,pag sumobra dyan ay may uneccessary load na nagconsume ng boltahe ng battery.check mo lang mabuti.at kung nasa mga .1-.2 amp nga.palagay ko alternator yan.im not sure.
    Actually dun sa binilihan mo ng Battery dalahin mo dun pwede cla mag-check kung ok ung Alternator mo kung kumakarga pa ng ayos, kc bka Battery din ang problem na-ddrain pero bhira yun pa-check mo saknila ung Voltage kc pag umaandar dpat ang measure na nya 13Volts dun pa lang malalaman mo na kung mahina talaga kumarga. Ang ESi 70Amp ang Alternator nyan, kya khit idling lang kyang-kaya nyan lahat accesories.
    Nov 2007
    sir try mo ipalinis ang solinoid ng starter mo o kaya baka kulang na sa ground ang car mo
    Nov 2006
    Very interesting....this happened to me as well, for the whole February to mid March (last week)....lahat ng electrical equipment ng car gumagana, pero pag start, ayaw mag-start. Kahit redondo wala. It just clicks then nothing happens.
    Sometimes I try to keep my hand turned at the start position until the orange engine light indicator lits up and some beeps start to chime. Sometimes it starts, sometimes it doesnt, lalo na pag malamig ang panahon....but if it starts, then you use it for a while, then turn it off, after a few hours it will start pa rin. But leave it overnight, like when you reach home after work then you start it up in the morning, ayaw nanaman umandar. Basta nalamigan....I tried turning on the lights, radio, etc. before i start, everything works right, except the starting of the car.
    But recently nung nag-change na climate (mainit na recently right?), lagi sya start 1 click. Di ko na kelangan magpatulak sa kapatid ko before going to work.
    Question: May heater ba ang accord????? Diba sa gas engines wala naman heater???? Bakit pag nainitan ung sasakyan, aandar. pag nalamigan, ayaw na, kahit redondo man lang? Thats why i doubted na battery problem eh... hope you guys help me too. thanks!
    Oct 2007
    Quote Originally Posted by ebzack1998 View Post
    Good Day Gys,
    Thanks,
    Markus
    sir check mo muna mga fuse mo baka may busted na!o di kaya sa computer box yan try mo buksan, at check mo rin grounding wires mo...and lastly, pa diagnose mo sa casa tapos ipagawa mo sa labas pag alam muna sira...
    just my two cents!
    sir, next time gamitin mo lahat ng keys mo sa keyboard para di mahirap magbasa.
    Sep 2004
    Almost one year na nung pinost nung TS yung problema niya. I'm pretty sure na by this time, solved na ang problem.
    Jan 2008
    OT na ito... last thursday lang nangyari na den sakin to with my ESI, and ganito ang nangyari why ayaw mag start ng sakin, kasi whiel driving in all powered vehicle i always used most of the powered gadet na meron gaya ng bukas sara ng power window, open headlight and fog light sa front bumper and aircon, and radio with set up sounds, tapos nung pakarga ako gas ayaw na mag start, did a kick start then yun nag start na, then check with the pulling your battery cable to check the alternator ok naman (BTW totoo yun to check if the alternator is good) i guess the car cant handle much of the powered gadet it has pati yung mga dinagdag rarely happen pag ganon ako gumamit ng car, been to baguio recently ok naman performance so atleast i know na ok yung oto... one click nga in any weather yung oto eh
    ill check na den if pwede apply yung mga given suggestion dito
My 95 Honda Wont Start!!!! Help
