Results 1 to 11 of 11
    Feb 2011
    mga sir good day..anu kaya problem ng car ko,sa umaga ok naman ang starting one clik lang.then pag ginamit ko na at nag turn off ako ng engine at start ko uli clik lang maririnig ko.pag off ko uli un key at on ko na ng ilan second start naman uli..PARA MINUMULTO AKO EH..hehehe.. madalas mangyari pag nag off ako ng engine at nalimutan ko naka nutral un trans ko..automatic po car ko please help naman mga sir.....
    helo sir, have your starter and starter solenoid check by your suking mechanic and also your ignition coil. hth
    Feb 2011
    di ko pa n papacheak..kumukuha pa ako ng idea sa mga pipol dito sa tsikot..hirap kasi sa mga shop pag dinala ko car ang dami n problema kaya mas ok un may idea..nagagamit p naman to car,pag turn off ko uli at on ko ng ilan second nag start naman cya..natatakot lang ako baka one day di na talaga mag start..
    Dec 2009
    Sir it happened to me before pag malamig ang engine one click and pag mainit na then nag off ako ng engine hirap eh start panay redundo lang need ko pa palamigin yung engine about.so nung nag palit ako ng starter back to normal na uli.pa check mo starter mo baka nag stuck-up starter ka pag mainit na yung engine at panay click lang naririnig mo.
    Apr 2011
    Ignition coil?
    Feb 2011
    ignition coil.san ba part ng car sir nkikita un..nkakapag taka lang kasi minsan wl naman problema..pero pag nalimutan ko naka nutral at na off ko engine saka lang ayaw mag start pero kung off ng ilan minute at i on ko nag start nman..
    Nov 2007
    Quote Originally Posted by atog View Post
    I encountered the same problem also before with my CRV, have your ignition switch checked, it is located at the back of the dash key panel, circular shape with wirings, there are carbon contacts there that might be worn out already, I replaced it problem solved. It cost 400 plus php during 2006. hth.
    Apr 2005
    Quote Originally Posted by D15B View Post
    ignition coil?
    distributorless na ang ignition ng ES. Hindi na ito kamukha ng old school ng makina na may iisang ignition coil.
    pareho tayo ng problema, accord ko din ganyan na ganyan.
    nag pa linis na ako ng starter motor, ganun pa din. next week papa check ko yung ignition switch naman.
    Feb 2011
    good day mga sir ok n car ko..starter selonoid pala problem..di n nag cocontact un seleniod sa starter..ask ko lang un electrician then ako nalang gumawa 1taw un selenoid...
    May 2011
    baka ignition coil yan, pacheck mo bka mdyo shorted na, u dont have to replace ang buong distributor kc may nabibili ng ignition coil..
vtec3 matic starting ploblem only cliking
