My 2012 Civic Odometer has no information displayed, walang mileage, trip A, B. Nangyari na ba sa inyong Civic ito. Ano ba remedyo nito before bringin it to Casa
Try this gauge cluster diagnostic procedure to check if all displays and indicators are working and go from there. This works on the 8th Gen Civic as well as the current generation Jazz.
1. Press and hold the Select/Reset button
2. Turn on the headlights
3. Set ignition to ON (do not start the engine)
4. Turn off the headlights, then on and then off
5. Release the Select/Reset button and press it three more times then release
This is what typically happens, again on the FD: YouTube
Problem solved. I disconnected the battery by removing the negative terminal for 15 minutes. Put it back and whoala the odometer, trip A,B , temp reading, average fuel concumption apppeared.
