Results 1 to 14 of 14
    Dec 2011
    Mga sir I have a civic 2000 lxi a/t, palitan ko sana yung stock fan ng radiator at condenser ng high speed denso fan na surplus.
    Ask ko lang kung may nakatry na nito? Worth it ba? Malaki ba improvement sa cooling system ng kotse?
    Nagtanong ako ng price sa evangelista 1,500 each yung denso high speed fan for radiator & condenser, ipipili daw ako ng sariwa, then 500 pesos yung installation.
    Need your opinions po, thank you so much in advance mga sir!
    Pa check mo muna ac system mo. There are lots of shops that can check and diagnose naman. If the fan is working and the temps don't go down then maybe there is something wrong with the system.
    Dec 2011
    Ok naman yung aircon system ko sir, actually kakapalinis ko lang ng aircon kanina. Gusto ko lang sana talaga mag-upgrade para mas cool yung engine bay.
    Jul 2013
    Quote Originally Posted by ArthMax View Post
    No amount of fan will significantly cool your engine bay.
    Either you open the hood or drive the car to force more cold air in and hot air out. The wont do this simply because of the enclosed nature of the engine bay.
    Dec 2011
    Quote Originally Posted by Lew_Alcindor View Post
    I mean bawas init lang sir, not actually to cool the engine bay, sorry for the wrong term I used.
    Jan 2009
    It's not needed. The car survived 21 years, apparently without any cooling system issues. Why change it now?
    Besides, "high-speed" doesn't come free... it requires a high current draw from a wiring that was probably not designed for it. You're also putting unnecessary load on the electrical system, battery, and the alternator. This translates to more engine drag and less usable horsepower, if you want to be pedantic about it.
    is the engine overheating?
    kasi,
    doing a thought experiment,
    it seems to me, that...
    kung hindi naman nag-o-overheat,
    strengthening the fan or upgrading the radiator won't amount to much,
    because the thermostat will close all possibilities when it chooses to close, regardless of what the fan's and radiator's capabilities are.
    if the stock car didn't need it before,
    then it probably don't need it now,
    unless there is something wrong.
    fix what is wrong, and do not be tempted with crutches.
    my opinion.
    Jan 2008
    palitan mo ng bagong radiator.. mas ok yun..
    Jul 2013
    I agree with the earlier comments, if its not giving you issues, better not replace it.
    Sep 2021
    Maybe its just typical Pinoy “creativity”.
    Japanese engineers came up with precise calculations on what specs are needed for your car to run properly as designed.
    But a few ingenious backyard mechanics think they know better (or want to make a fast buck)
    1,500 pesos for a brand new denso hi speed fan?
    parang... cheep.
    kung surplus naman,
    nakaka-takot.
    how do we know it's still functioning as it should?
    Jan 2009
    OP, wag ka magpa sales talk sa mga tao dyan. I bet sila din proponents ng “tanggalin na natin boss thermostat nyo. Hindi naman yan bagay sa pilipinas. Para sa malalamig na klima lang yan”.
    O di kaya, “rekta na natin aux fan ninyo para iwas overheat”.
    Anyway, baka kulang lang yan sa blinker fluid.
    Jul 2013
    Kung mas malakas na fan sa condenser, it will help your AC in putting out cooler air especially when the vehicle is not moving.
    Pero kung ang aim is for a cooler engine, wag na kasi may mechanism ang kotse to maintain that optimum temperature.
Upgrading Radiator & Condenser Stock Fan to High Speed Denso Fan (Civic 2000 Lxi A/T)
