Honda's
automatic transmissions are unusual in that they do not use
planetary gears like nearly all other makers. Instead, the
Hondamatic and its successors use traditional sliding gears in parallel like a
manual transmission. Honda was forced to invent their new system due to the vast array of patents on automatic transmission technology held by
BorgWarner and others.
Honda initially chose to integrate the transmission and engine block for its first application (in the
N360) as in the
Mini. The Hondamatic incorporated a lockup function, which Honda called a third ratio, and had manual gear selection. The company's early transmissions also used a patented
torque converter which used stator force rather than hydraulic controls for shifting.
The company's naming scheme is also confusing, as it is specific to a single model of vehicle and some identifiers are reused.
