pa-add na rin ng tanong mga bros. i have the same thing with the TS. most of the time, nauubos yung coolant sa reservoir ng oto ko. pero minsan pag check ko, bumabalik din yung coolant ulit sa reservoir. knowing that, naglalagay na lang ulit ako ng konting coolant just to be safe. no sign of leaks visually & i'm not experiencing overheat naman and the temp gauge is always at halfway position. ok din nman ang takbo ng engine.
btw, nag top overhaul na ako last dec2008 (replaced head gasket, machined shop etc) and ever since, wala naman overheating issues since then. it's just that recently, nakikita ko nga na ubos yung laman ng reservoir. praning kasi ako na inspite of this, baka meron na palang internal damage without me knowing it or at least it could have given me visual cues of the problem.
is this a normal occurence/issue? thanks in advance bros
