Results 1 to 18 of 18
    Feb 2012
    What do you think? I'm planning to buy.
    Please give me inputs
    get a local unit
    Feb 2012
    what is the difference with local and japan surplus? pwera convrted sya
    may fit na 4wd
    Feb 2012
    why you suggest na I get the local unit?
    coz its converted?
    yep
    too short
    Feb 2012
    too short of what? pls elaborate
    Quote Originally Posted by shahn_101 View Post
    Don't worry, high lang sa rugby si Renzo ngayon.
    Yes, do try and get the local ones if you can. I read some are happy with their converts but if you look at the price difference between a 2004/05 to 2007 Jazz, its not really that big. Second issue is if its a Cebu unit, you'll have a Y-prefix plate number. Takaw yan sa mga HPG who are on the prowl for hot cars.
    too short yung message nya na "yep". at least 10 characters ata para mapost yung message.
    ^ tama
    too short
    Feb 2012
    akala ko maayos ako nagtatanong maayos din ako masasagot.
    sensya na.
    maayos naman sagot ko ah
    as if your questions arent answerable by a yes or a no
    sige let me elaborate
    converted units are always a risk
    di mo alam pano cinonvert yan
    you dont even know the person who converted it
    thats just the start
    pano ginamit ng previous owner yung kotse? no idea ka diba since it's surplus
    then here comes the issue of the plate number
    B,R,Y plates are "hot"
    Feb 2012
    meron po kasi ako tanong na why you suggest???
    kaya po hindi sya answerable by YES or NO!
    Salamat sa mga suggestion mo...
    TS - sir Chillax lang, i think ang gusto sabihin sayo ni master renzo e wag ka na bumili ng Honda Fit surplus kung ayaw mo ng sakit ng ulo, pero kung gusto mo talaga bumili ng Jazz, make sure kunin mo ung Local unit para iwas sakit ng ulo. BTW TS have you consider Suzuki Jimny? 1.3 engine, Higher ground Clearance than honda Jazz, 4wd etc.
    It is.
    You said: Why do you suggest that I get the local unit? Is it because that it's converted?
    Yes! It, being converted is one factor that I suggested that you stay away from them.
    Init panahon. Hehehe. Pati mga tao mainit rin.
    Anyway, sakit ulo converted pero meron naman hinde nagkakaproblema depende sa nagconvert yan
    Mar 2011
    I'm from Cebu. I see a lot of these Fits running around. I was able to drive one last year. My kabarkadas and my gf's dad owns one. So it's really a popular choice here.
    Basically, you get a FIT if you're really strapped for cash and cannot afford to get a brand new one or a good 2nd hand car. Ofcourse Jazz units will always be better than the FITs. FIT is a major option should your budget be around the 250 - 300k only mark. If you get from a good shop and know a lot about cars, you can get a Fit and fix it up to drive well with minimal problems. The one I drove last year kinda had problems in the wheel alignment and U-turn radius was wide due to the conversion. But it still ran may sunroof pa. I recommend the FIT only if you're on a low budget.
    my Plate is Y and its not a HOT CAR. New Cars here in Cebu start with Y already.
    i know that cars from cebu already has Y plates in it
    i have a relative there their cars start with Y
    that's not a problem ... when you're there
    but bring it here then it will attract a lot of 'crocs' hailing you here & there and check your papers
    B & R plate-numbered vehicles experience this as well
    Apr 2012
    +100 here!
    get a local unit para walang skit sa ulo. try and tested na yan.. just read some other forums.. they advise to get a local unit instead the converted Honda Fit.
honda fit cebu
