Results 1 to 2 of 2
- Feb 2006
- 1
April 15th, 2006 04:34 PM #1ENGINES 09209456737/ 09223162580
K20a type R rsx SOLD
B18c5 type R '96specs
B16b type R '00specs
4age 6th speed 80k
type R PARTS
K20a head cover 10k
K20a head, cams w/ gear (chain drive) SOLD
K20a intake manifold, throtle body, injectors SOLD
B18c5 head cover (may gasgas) 3.5k
B18c5 head assy 23k
B18c5 cams w/ gear 12k
B18c5 intake manifold, throtle body 62mm, injectors 270cc 23k
B18c5 ecu box P73 w/socket, distributor, harness, o2 sensor 18k
B16b head cover (sariwa) 5k
B16b cams w/ gear '00specs 18k
B16b intake manifold, throtle body 60mm, injectors 240cc 18k
B16b ecu box w/socket, distributor, harness, o2 sensor 18k
K20a tranny lsd (manual 6th speed), flywheel, pressure plate, clutch disc, shifter SOLD
B18c5 tranny 4/4 engage (ats) 75k
B18c5 tranny 4/4 lsd 50k
B18c5 tranny 4/7 lsd SOLD
B18c5 flywheel 15lbs, pressure plate, clutch disc 6k
B18c5 pressure plate, clutch disc 3k
B18c5 axle 3pcs 12k
B18c5 alternator 45amp. 3k
B18c5 compressor denso 10pa15c 3k
B18c5 starter (reduction type) 3k
B18c5 power strg 2k
B18c5 half block/ short block 81.2mm
B16b half block/ short block 81.2mm
B20b block/ short block
B18c5 crank pulley 3k
type R EXHAUST SYSTEM
dc5 exhaust manifold, catalytic, 10k
dc5 resonator 5k
dc5 muffler SOLD
dc2 exhaust headers 4/1 SOLD
dc2 exhaust manifold 4/2/1 3.5k
dc2 exhaust pipe stainless 6k
dc2 muffler 4k
ek9 exhaust pipe stainless 8k
ek9 muffler SOLD
type R INTERIORS
dc5 shift knob 6speed 3k
dc5 guage 8k
dc5 steering wheel w/ air bag (vtec3, crv) 12k
dc5 recaro sr5 red w/railings SOLD
dc5 carpet red 3.5k
dc5 matting red SOLD
dc2 shift knob SOLD
dc2 shifter assy 7k
dc2 guage 5k
dc2 steering wheel w/o airbag 8k
dc2 recaro sr3 w/railings red 36k
dc2 matting black 3k
ek9 guage 15k
ek9 steering wheel w/ air bag 12k
ek9 recaro sr5 red w/railings 36k
ek9 carpet/ matting red 10k
type R SUSPENSIONS/ BRAKES/ MAGS
dc5 hydrauvac assembly 5k
dc5 shocks n springs (vtec3) SOLD
dc5 BREMBO disc brakes front n rear 5lugs pcd114
dc5 mags 17" 5lugs pcd114 35k
dc2 hydrauvac assembly 15/16", 1" 3k
dc2 shocks n springs (eg) 8k
dc2 disc brakes front n rear 4lugs pcd114 12k
dc2 mags 15" 4lugs pcd114 wid tires 18k
ek9 hydrauvac assembly 3.5k
ek9 shocks n springs 12k
ek9 disc brakes front n rear 5lugs pcd114 25k
ek9 mags 15" 5lugs pcd114 wid tires 18k
- Oct 2006
- 2
October 24th, 2006 12:15 PM #2hi man! how much are u selling your engines? also, do you have a shop na pwedeng puntahan to take a look and test these out? what warranties do u give?
thanks in advance for the reply!
high idle RPM at engine start
