Results 1 to 14 of 14
    for those vdub geeks out there, I just bought this 1990 GLI 2.0 16V last month.
    lowered her with bilstein sports/neuspeed sports
    replaced the aero ligths with Euro quad lights, 7" H4's, 5" driving inner H3's.
    removed the tints.
    lowered.
    the engine bay when I got her.
    some technical specs.
    Year 1990
    Engine Code 9A
    Rated Hp 134hp
    Engine size 1984cc
    Bore X Stroke Fuel 82.5X92.8mm CIS Motronic
    Miscellaneous facts:
    -1988 was the first year of the 16v engine
    -The GLi was only offered in two different displacements: 1.8liter and 2.0 liter
    -Standard equipment on most GLi's included: Recaro seats VDO gauges, including MFA, integrating Oil temp, Gas milage, trip odometer, outside temp, time, and time of driving into one digital gauge 15X6 inch BBS alloy wheels in a variety of patterns Bosch electronics and fuel injection - While the GTi was introduced in 1983, the american public did not recieve the GLi until 1984
    - The GLi was one of the first VW's to add any aerodynamics specific to a model - the inconspicuous rear trunk wing
    bits.1990 Jetta GLi Stock Specs:
    2.0 Liter, 134HP, 16 Valve 4-Cylinder Fuel Injected Engine
    5-Speed Close Ratio Manual Transmission
    Power Assisted Rack and Pinion Steering
    Sport Suspension, Independent MacPherson Strut Front Suspension,
    Independent Torsion Beam Axle Rear Suspension,
    Front and Rear Stabilizer Bars
    Sport Tuned Suspension, Dual Tipped Exhaust Pipe
    Engine Specs:
    Type 4 Cylinder, In-Line
    Displacement 121 Cu. In. (2 Liter)
    H.P. * RPM: 134 * 5,800
    Trq. Lbs.-Ft. *RPM 133 * 4,400
    Valve Train:
    Dual Over Head Cam, Spur Belt Driven,
    4 Valves per Cylinder, Hydraulic Lifters
    Cooling System Water Cooled, Cross-Flow Radiator,
    Water Pump, Thermostatically Controlled
    Electric Radiator Fan
    Fuel/Air Supply Fuel Injection (KE - Motronic)
    Emission System 3-Way Catalyst, Oxygen Sensor
    Heavy Duty Cooling
    Close Ratio 5spd (020 2Y) Gear Ratios:
    1st -3.455
    2nd -2.118
    3rd -1.444
    4th 1.129
    5th .912
    Final Drive -3.667
    Front Suspension:
    Independent MacPherson Struts,
    15mm Stabilizer Bar, Coil Springs,
    Telescopic Shock Absorbers
    Rear Suspension:
    Independent Torsion Beam Axle,
    20mm Stabilizer Bar, Coil Springs,
    Brakes:
    Dual Diagonal Circuits with Power Assist,
    Vent 10.1" Discs Front,
    Solid 8.9" Discs Rear, Self Adjusting
    Parking Brake Mechanical to Rear Wheels
    Wheels 6 J x 15 BBS Alloy
    Tires 185/50VR15V Steel Belted Radial Tires
    Engine Oil 4.3 Quarts with Filter
    Fuel 14.5 U.S. Gallons
    Cooling System 7.3 Quarts
    Top Speed 125 mph
    Acceleration
    0-50 mph 5.7 sec.
    0-60 mph 7.8 sec.
    40-60 mph
    EPA Estimates (City/Hwy.)
    50 States 22/28
    weight ~2450ish ?
    Front Spoiler with Brake Cooling Ducts (not hooked up)
    Rear Spoiler
    Integrated Bumpers with Color Keyed Front & Rear Trim
    Black Fender Flares
    Dual Remote Controlled Outside Rearview Mirrors w/Color Keyed Housings
    Two-Speed Wipers with Intermittent Feature andDriver's Side Deflector
    Narrow Body Side Molding with Integrated GLI Nomenclature
    Black VW Front Grille Badge, Window Trim & Door Handle Inserts
    Roof Mounted FUBA Antenna
    6J x 15 BBS Alloy Wheels
    Speedometer, Tachometer,
    Trip Odometer, Fuel Gauge, Coolant Temp. Gauge,
    Digital Clock, Warning Chimes & Lights
    On Board Multi-Function Trip Computer
    Center Console with Ashtray
    Power Height Adjustable, Fully Reclining Recaro Front Bucket
    Seats with Adjustable Headrests
    Height Adjustable Steering Column
    Leather Wrapped 4-Spoke Steering Wheel
    Automatic Shoulder Belt System with Manual Lap Belts
    3-Point Outboard Rear Seatbelts with Center Lap Belt
    Velour, Multi-Colored Upholstery & Dark Grey Trim
    Velour and Leatherette Door Trim Panels
    Full Cut Pile Carpeting, Full Luggage Compartment Trim
    Electric Rear Window Defroster
    Tinted Glass
    Courtesy and Dome Lights with Time Delay
    Right Hand Vanity Mirror (Illuminated)
    Left Hand Vanity Mirror
    Locking & Illuminated Glove Box
    Front Door Map Pockets
    Right Front Assist Handle
    Rear Assist Handles with Coat Hooks
    Air Conditioning
    Manual Sunroof
    my 1985 VW GTI
    nice car dre.... vw fan din kasi ako eh (specially yung mga old style na golf)
    looks like there's a bit of space in there for a t3 turbo :evillaugh:
    or two
    ganda ng Euro Quad Lights ah :cool:
    ahhh, that '85 GTi, almost had me on a street race. A port and polished head pala
    baka 16v yung naka street race mo?, daming options most a2's(1985-1992) here in colorado are running vr6's, some stock 2.0 16v, merong yung naka 8v pero 2.0 yung pang-ilalim pero para lang 1.8ltr 16v yun unless naka carb, meron ding mga naka g60 supercharged.
    ewan ko 1.8T, we actually stopped at the traffic light to compliment each other's run. Una, sabi nya stock lang sya, sabi ko imposible. Ayun, umamin na naka PnP then some other internal mods. mabait yun tao, nakikita nya daw ako araw-araw sa avenue nila, hindi kagaya ng mga young bloods na nakikita ko sa daan. He was trying to decide between EVO 8 or STi, it was 3 months ago, ano kaya ang nabili nya?!
    nga pala, I always loved the Corrado. Someone was selling his 1992 Yellow one for $2,500.00 pero the cost to maintain, I dont wanna deal with.
    ganda ng corrado, pero tawag namin dun eh parts car kasi palaging merong nasisira, hindi reliable yung supercharger ng g60 corrado, mas ok payung vr6 or papalitan ng bahn brehner na super charger.
    parang ayokong i-turbo yung 16v ko, attainable naman yung 180-190+hp na hindi naka turbo sa mga 2.0 16v at saka I still have my 1.8T jetta
    eto mga naka tubo na 16v.
    16v turbo corrado w/ vr6 hood
    sample 16v turbo.
    Ran a best of 13.7 * 111mph!
    Pulled 206whp*7000rpm and 183ft./lbs. * 5300rpm * 12psi on the dyno.
    Engine :
    · T3 Super 60, .82 hotside w/internal wastegate
    · Turbonetics exhaust manifold
    · Custom downpipe
    · 450cc injectors
    · Audi intercooler
    · SDS EM3-F Engine Managment
    · 2 stock headgaskets stacked
    · ARP headstuds
    perfect fit! hehe...
    May 2005
    Just wanna say :hi:
    Too bad I can't view some of the pix.
a little vw lovin
